what would cause??
Old May 6, 2007 | 09:52 PM
S2martin's Avatar
S2martin
Ex Full Price gold member
Default what would cause??
On a 1.8 zetec what would cause when coming to a stop and putting the clutch in (or sometimes but very rarely when changing gear) the revs drop as normal but dip right down into the bottom of the rev counter and then the engine will stall?
When sitting there ticking over it isnt a problem no fluctuations (spl) in the revs or anything just the issue with pulling up to a stop mostly??
Mart
Old May 6, 2007 | 09:56 PM
James's Avatar
James
Try cleaning out the idle air control valve.
if that does nothing try a different vehicle speed sensor.
Old May 6, 2007 | 10:30 PM
N1ck's Avatar
N1ck
sounds like something to do with the idle...
Old May 11, 2007 | 06:04 PM
S2martin's Avatar
S2martin
Anyone else in the know?
Old May 11, 2007 | 06:11 PM
pee vee's Avatar
pee vee
zetecs are terrible for the idle control valves going mate.
i'd jsut replace it.. cleaning dont really do much in my (limited ) experience
Old May 11, 2007 | 06:14 PM
RichieST's Avatar
RichieST
if it isnt the iscv, could it be egr related??
Old May 11, 2007 | 06:24 PM
Try a new TPS, this will cause it as just fixed a mondy auto with exact same problem, nothing showed on ford computer!!
Old May 11, 2007 | 07:54 PM
S2martin's Avatar
S2martin
Thanks for the help guys
I'm gonna give it a full service this weekend and try a few of the solutions
Thanks Tabetha will try that first
Mart
Old May 11, 2007 | 08:21 PM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
Usually it's the vehicle speed sensor. Located near the point where the speedo cable joins the gearbox.
Old May 11, 2007 | 08:31 PM
twister's Avatar
twister
I would say speed sensor as well from experience
Old May 11, 2007 | 08:33 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
On other engines its often the ICV, but on zetecs is common for it to be the VSS im led to believe.
Mine does it too (1.8 mondeo) but not bad enoguh for me to be arsed to fix it, lol
Old May 11, 2007 | 08:34 PM
S2martin's Avatar
S2martin
Ahhh so the plot thickens lol,
Cheers guys might as well do that too then
Old May 11, 2007 | 08:41 PM
Ginge !'s Avatar
Ginge !
just finding my feet
cause the idle is fine its the spee sensor
Old May 11, 2007 | 08:49 PM
S2martin's Avatar
S2martin
Cheers Ginge
Old May 12, 2007 | 01:04 AM
Are you sure it is not lumpy when it idles ?
Try also checking the "T" piece.
Old May 12, 2007 | 07:43 AM
S2martin's Avatar
S2martin
She is a touch lumpy on tick over but never enough to even attempt to stall happily sits there ticking over but does fluctuate (spl) a little but i put that down to wanting a good service (ooer lol)...
So on monday i am getting..
plugs
leads
oil filter
air filter
oil obviously
sump plug
new tps any idea how much?
new speed sensor as above?
I'm going against it being the ISCV as she doesnt behave like the last couple of zetecs i've had with ISCV troubles as in coming to a stop but the revs stay high or during gear change the revs rise dramaticaly..
Mart
Old May 12, 2007 | 08:12 AM
sedan man's Avatar
sedan man
gaurantee its the iscv had extactly the same problem on my 1.8 si escort..
