what could cause...
06-05-2007 | 09:37 PM
what could cause...
The cossie to die whilst boosting,go off the trotle for a split second then it boosts again normaly??
06-05-2007 | 09:39 PM
06-05-2007 | 09:41 PM
Quote:
Originally Posted by plynchy
It's shit.
fuck off dole wolla,when you sighning on
06-05-2007 | 09:43 PM
Don't need to grafter, man of leisure.
06-05-2007 | 09:44 PM
phase sensor and or crank sensor i have been ther
06-05-2007 | 09:46 PM
acuator,phase sensor,crank sensor,
Explanations of why you think that
06-05-2007 | 09:49 PM
amal valve.
this controls the boost aswell as the actuator opening the wastegate.
06-05-2007 | 09:51 PM
because by the sounds of it you are on boost and then the car dies and you have to come of the throttel and back on it to be back on boost am i right
06-05-2007 | 09:53 PM
Clive, is the engine cutting out or are you loosing boost pressure?
steve
06-05-2007 | 09:57 PM
boost mate
06-05-2007 | 10:02 PM
righthooker
so your only lossing boost ie you hit 26 psi and it drops to 19 psi then it could be as dave4x4 have siad
06-05-2007 | 10:05 PM
yup sounds like a dodgy amal valve
if I remember the connections on your amal valve are shonky as fook, check the wires
steve
06-05-2007 | 10:07 PM
Ask a sparky, but they may tell you to fuck off.
06-05-2007 | 10:57 PM
It boosts up then no boost whatso ever unles i release the throtle,wires are ok steve ,could be a number of things i suppose.
Will be geting Big wing sump and set up this week anyhow ,so Niel can sort it then
07-05-2007 | 12:24 AM
and a gallon of petrol and a box of matches lol
jk
how u doing fella
07-05-2007 | 09:30 AM
if its the amal/wiring take the valve apart and remove the spring and weight inside....done this on mine...works a treat
FletchCossie
29-12-2005 02:02 PM
James Raby
29-10-2004 11:53 AM
