stud conversion on mk4 escort
Old May 6, 2007 | 05:41 PM
marky_g's Avatar
marky_g
Fleet Manager
Default stud conversion on mk4 escort
rite i have all the bits but what size to u have to drill the old holes out too????
any help would be greatly appreciated
Old May 6, 2007 | 05:43 PM
What studs are you talking about ?
Old May 6, 2007 | 05:59 PM
marky_g's Avatar
marky_g
Fleet Manager
there brand new ford wheels studs just need to know what size to drill out existing holes to
Old May 6, 2007 | 06:25 PM
marky_g's Avatar
marky_g
Fleet Manager
anyone?
Old May 6, 2007 | 06:35 PM
Ginge !'s Avatar
Ginge !
just finding my feet
depends what studs you got
Old May 6, 2007 | 06:37 PM
nigel b's Avatar
nigel b
if they are m12 studs drill it 10.2
Old May 6, 2007 | 06:46 PM
marky_g's Avatar
marky_g
Fleet Manager
i just asked for std wheels studs from a mk5 escort
what are they????
Old May 6, 2007 | 07:53 PM
project rs's Avatar
project rs
i think i drilled mine out to a 12mm best way is to run a drill bit through to take thread out and see if yours fit then if not increase a mm at a time to they do. its easier to use a wheel nut to pull stud through rather than hammering them in and less likely to damage anything
Old May 6, 2007 | 08:58 PM
iansoutham's Avatar
iansoutham
OCD Victim
Or, you can contact someone like Keeef @ Elitedirect.com and get him to send you the conversion studs I use. You wind them into the flange from the rear using some red lock-thread. Then, you peen the 1st thread over @ the front of the flange to make definitely secure (well, I do anyway). Then fit everything back up. No drilling or anything, and you can always remove them if necessary to refit original-style wheels (unless you have peened them over, then it is harder to remove them).
The problem with drilling the original flange is that the MK5 studs have a fine seration designed for MK5 flanges. The problem with using them on a MK4 that has been drilled is if they decide to spin in the hole @ a late stage when trying to remove or refit a wheel. 70lb ft torque on a torque-wrench can cause them to slip.
Old May 7, 2007 | 10:54 AM
marky_g's Avatar
marky_g
Fleet Manager
not if u tack weld the backs
or get mega tight fir this is a budget thing its 4 my xr3i so no std wheels will ever see that car again it was winter pack they were steels lol
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
hopper350
Sep 4, 2015 12:53 AM
Bighandsuk
Sep 2, 2015 05:23 PM
Vincereese
Aug 18, 2015 03:57 PM
