DIY Throttle cable kit
Old May 1, 2007 | 10:45 PM
JonnyBravo's Avatar
JonnyBravo
Default DIY Throttle cable kit
Does anyone know where I can get a throttle cable kit ? I've looked on ebay and there all for bikes.
I could do with one that has good enough fittings for the loud pedal, other end if for a underslung linkage on some throttle bodies
Old May 2, 2007 | 05:15 AM
You could just buy a rear brake cable for a bicycle and use cable clamps.
Old May 2, 2007 | 07:36 AM
JonnyBravo's Avatar
JonnyBravo
Good thinking, and that will be a lot cheaper than one of those kits !
Theres a bike shop round the corner so I'll pop in later
Thanks
Old May 2, 2007 | 10:51 AM
AX Cossie's Avatar
AX Cossie
i got a universal one from gsfcarparts.com for my AX.
Not sure if it will have the fitting you need.
Old May 2, 2007 | 11:01 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
is your std one long enough for where you need it to go?
i just bought a cable nipple that screws against the cable when i fitted bike carbs to my escort
http://www.merlinmotorsport.co.uk/CA...duct_info.html
Old May 2, 2007 | 11:23 AM
JonnyBravo's Avatar
JonnyBravo
Its on a vauxhall nova with a xe.
I'm going to use a normal astra throttle cable outer and bracket mounted on the back of the block.
The cable isn't long enough to go from bracket to the linkage on the throttle bodies.
I think the bike cable idea would work perfectly, I'll grab a couple of those cable nipples though as they will be handy in an emergency
Thanks all
Old May 2, 2007 | 03:27 PM
xr-stu's Avatar
xr-stu
www.nfauto.co.uk , might be .com but cant rmemebr! theyre a kitcar supplier, they doa couple of different length ones i think! even for rear engined cars so will be AMPLE long enough for you!
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
