3dr Oil Cooler location
Anyone got any pics of oil coolers mounted in front of the IC on a 3dr? Not sure if it will make the front end look too "fussy"
Mine is behind the fog grill but I am thinking of moving it...............basically because I am a tart and haven't had a chance to do anything with the cossie this year
Only thing is my oil sits at around 80 degrees as it is with half the cooler blocked so might be a too cool with it all exposed. Then there is the issue of blocking the IC. On the plus side it will look bling
Re: 3dr Oil Cooler location
Consider though that if you leave it exposed at the front, and take stone straight through it, it could mean your engine.
Got all excited then.....................then saw the replies were from you two
I have just re-read this post and realise it sounds a bit pretentious and possibly ghey.
Cant get on MSN at work dude, PM me
