View Poll Results: Turbo oil feed filter
Yes
56.25%
No
43.75%
Voters: 32. You may not vote on this poll
Turbo Oil feed filters. Good or bad idea?
Old 30-04-2007, 08:08 PM
boXXer
GASH!
boXXer's Avatar
Default Turbo Oil feed filters. Good or bad idea?
Ive been told i should buy a in-line turbo oil feed filter for my new T34, but ive heard bad things about these, but i cant remember what.
Are they reccomended? or shall i leave alone?
Cheers!
Old 30-04-2007, 08:10 PM
Mr S1
Don't ask - I don't know
Mr S1's Avatar
Bad IIRC. If it blocks then no oil to engine and turbo.
Bypass the whole thing and change the oil regularly.
Mikey - say hello to dad for me
Old 30-04-2007, 08:15 PM
Lloyd
escort mk4 cossy 4x4
Lloyd's Avatar
only needed on a gt turbo.
Old 30-04-2007, 08:31 PM
RichardPON
RichardPON's Avatar
The reason they have a bad rep is because some of the Bailey ones screw into the turbo itself, and when dumb owner (of which there are many in the Ford world! ) overtightens it, it can crack the casing.
There's also the blockage issue, but they should be maintained as per any serviceable item........ which of course they are not which adds to the reputation etc...
Having said that, I'm never sure how necessary they are on stuff like T34s. As long as you prime the turbo, and replace the feed pipe (so cheap, it's crazy not to), and flush the oil through, you already have an oil filter on the engine, so it seems like overkill IMO.
Old 30-04-2007, 08:36 PM
Jasesapphy
Jasesapphy's Avatar
Turbo dynamics recommend fitting them t34's and changed every 15,000 miles
Old 30-04-2007, 08:38 PM
Bullett
Bullett's Avatar
i got one for mine.and as pon says its all downto regular oil changes and cleaning of the filters imo.
Old 30-04-2007, 08:39 PM
RWD_cossie_wil
RWD_cossie_wil's Avatar
Amazing that no one has developed one yet with a bypass valve and poppet indicator must be cheap enough to make and ALL the oil filters on the Aircraft I work on have them fitted, so it's easy to see if they are blocked/ restrictive
Old 30-04-2007, 09:21 PM
Si B
2Evos & 1 Escort Van :-)
Si B's Avatar
I have one, VERY HAPPY with it.
I've killed 4 turbos due to "oil contamination" according to the manufacturers. Since fitting my Bailey one, no dead turbos.
IMHO worth every penny.
I have always regularly changed my oil and filters, and since the pre filter was fitted, this too has been regularly checked and cleaned.
Get one I say, regardless of turbo type.
Si
Old 30-04-2007, 09:29 PM
boXXer
GASH!
boXXer's Avatar
UH oh, i KNEW it wouldnt be an easy yes or no. The bloke i got the turbo from said i should use one, but i was sure some people had grief with them. I dont fancy killing my spanking turbo.
Old 30-04-2007, 09:31 PM
Si B
Si B's Avatar
Personally, I'd do as your supplier says. Else you KNOW he's going to say no filter no warranty if/when it fooks up!
Old 30-04-2007, 09:34 PM
boXXer
GASH!
boXXer's Avatar
actually, he did! lol.
boXXer
GASH!
boXXer's Avatar
BTW, which manufacturers make them?
Si B
Si B's Avatar
Er, oops...
Old 30-04-2007, 09:36 PM
RichardPON
RichardPON's Avatar
They always do, because most people just slap the turbo on.
In that case, when turbos have died from "oil contamination", 9 times out 10, they've been fitted incorrectly.
Just do an oil change at the same time, and flush the oil through so that it's clean past the filter.
Old 30-04-2007, 09:37 PM
Si B
Si B's Avatar
Mine is a Bailey one... can't speak of other brands, but mine has been doing its job nicely.
Si
Old 30-04-2007, 09:42 PM
boXXer
GASH!
boXXer's Avatar
its actually not been run at all yet. Its a fresh build, so may as well put one on for the sake of it. Bailey have one where you get a new oil line, and the filter goes in-line instead of screwing into the turbo. Might go for that one
Old 30-04-2007, 09:51 PM
RichardPON
RichardPON's Avatar
That would be the better choice.
Old 30-04-2007, 09:56 PM
Carlsworth
Former Sponsor
Carlsworth's Avatar
it is a good idea, but as pon rightly says, most turbos die because of oil contamination....
so, you have to be absoultely sure the oil is crystal...
thing is....
if the oil is shit, it will eventually kill the turbo..
if the turbo oil filter clogs up, the turbo will die.....but much more quickly..
carl
Old 30-04-2007, 10:05 PM
boXXer
GASH!
boXXer's Avatar
ok thanks, Think i'll order one tomorrow then
PGT
PGT's Avatar
my t34 died after about 500 hard and 2k easy miles with no filter + never had water cooling but was careful at close down of engine. at rebuild they said 'it looks like oil contamination'!!!
Old 30-04-2007, 10:11 PM
CozzyBrom
CozzyBrom's Avatar
if a turbo lets go the warrenty aint worth the paper its writen on
makes me laugh we buy a gt 35 good for and speced for say 650 bhp but the green card with warrent details states its only sposed to be ran at standard boost or warrent is invalid
we all still buy our turbos knowing this or turbo makers say its ran to much boost or claim the oil thing
luckly i never had a turbo get go on me
yet !!!!!!!
Old 30-04-2007, 10:12 PM
Carlsworth
Former Sponsor
Carlsworth's Avatar
yet !!!!!!!
you ve fooked it now brom
Old 30-04-2007, 10:14 PM
CozzyBrom
CozzyBrom's Avatar
i was thinking that as i was typing it
Old 30-04-2007, 10:19 PM
CozzyBrom
CozzyBrom's Avatar
yet !!!!!!!
can you stock me up on some built up cores so when it goes bang i just change me compresser housing and exhaust housing
Old 30-04-2007, 10:21 PM
Carlsworth
Former Sponsor
Carlsworth's Avatar
what turbo is?
carl
Old 30-04-2007, 10:25 PM
CozzyBrom
CozzyBrom's Avatar
gt 35/40 r or somthing like that but i do want a gt30 i may try but will it be ok if the engine is reving to 9300
Old 30-04-2007, 10:32 PM
Carlsworth
Former Sponsor
Carlsworth's Avatar
dont think anyones has a gt30 on a fireblade before...
i can get you a price for a single chra, which you will be able to just bolt into the exisiting comp housing and ex housing...
ill get a price for a few also,...
you probably need 10 spares at 9300 revs...
Old 30-04-2007, 10:41 PM
CozzyBrom
CozzyBrom's Avatar
my engines a dry sump screemer
just wana try dropping revs n a gt30
Old 30-04-2007, 10:46 PM
Carlsworth
Former Sponsor
Carlsworth's Avatar
ill be in touch
Old 01-05-2007, 07:08 AM
Why change the feed pipe, if it is not blocked it flows oil!!
Old 01-05-2007, 07:39 AM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
http://www.randbmotorsport.co.uk/sho...?ProductID=187
Old 01-05-2007, 07:41 AM
Franco
Franco's Avatar
Lets hope they work!
Old 01-05-2007, 07:49 AM
RichardPON
RichardPON's Avatar
Because lots of them ARE blocked, and often haven't been changed in 15+ years.
Seen enough coming off of cars in some hideous states.......
Old 01-05-2007, 07:53 AM
Franco
Franco's Avatar
Also to add they can be bought off ebay for a tenner, so for the price of a new fuel filter it would be rude not to!
Old 01-05-2007, 11:29 AM
boXXer
GASH!
boXXer's Avatar
franco, did yours come with the pipe from filter to turbo aswell? i.e, the whole lot? and can you use that filter with a cam cover? cheers!
Old 01-05-2007, 11:41 AM
Mike Rainbird
Caraholic
Yes it comes as a full kit (just not the P-clips that attach the filter to the cam cover) - see my link above .
Old 01-05-2007, 11:55 AM
Nash
Cake lover!
Nash's Avatar
Out of interest does anyone know what size P clips are needed. I need 2 for mine but dont have my car at the minute to measure them.
Old 01-05-2007, 11:57 AM
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
I dont think it is a good or a bad idea. Its just down to if you want one or not. Did the RS500 touring cars use one? If not, then why the fuss
Old 01-05-2007, 12:00 PM
GARETH T
GARETH T's Avatar
i use my oil filter to filter my oil
Old 01-05-2007, 12:01 PM
Nash
Cake lover!
Nash's Avatar
I dont think so but was almost 20years ago and things move on, plus with a race engine things like that would be classed as a consumable part so didnt care about them lasting that long.
Quick Reply: Turbo Oil feed filters. Good or bad idea?
