Brake Package MIKE R maybe??
Old 30-04-2007, 09:11 PM
  #41
Ryan
Ryan's Avatar
is the bias valve the one at the rear of the car next to the chassis rails?
or are they at the bottom of the ABS distribution block?
cheers for the info again alan
Old 30-04-2007, 09:23 PM
  #42
rapidcossie
rapidcossie's Avatar
Its at the back of the car Ryan.
Old 30-04-2007, 09:25 PM
  #43
Jamz
Jamz's Avatar
I had 330mm 4-pots on my 500bhp 2wd Sapphire
PMSL and what happened to that car ?
Old 30-04-2007, 09:42 PM
  #44
Moose 130
Moose 130's Avatar
I run 330's and Porsche calipers on mine with 4x4 rears and she stops damn well!
I've got Wilwood 330's & 6 pots on another car and the quality of the kit is excellent.
Not tries AP's, so can't comment.
Old 01-05-2007, 07:49 AM
  #45
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Euan,
You answered your own question you nuggart, you removed the original bias valve, so of course you will have issues then .
My Sapphire didn't crash due to LACK of braking, in fact completely the opposite . I jumped on the brakes (as per usual), expecting the ABS to sort it all out, and the Performance Friction pads / APs did their stuff, but I forgot that I had switched off the ABS .
Old 01-05-2007, 12:05 PM
  #46
rapidcossie
Euan,
We removed the bias valve when I still had the standard rear set up to try and get some heat in the rear brakes.
Old 01-05-2007, 12:12 PM
  #47
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
Mike,
why did you switch the abs off or had you just come off a track day as i know people tend to want no abs when on track for some reason
Old 01-05-2007, 12:47 PM
  #48
Mike Rainbird
Caraholic
Euan,
Well by removing it, you cetainly achieved your aim . But if this is retained, then there is no issues, even when going to 300mm diameter .
Originally Posted by CossieRich
Mike,
Because around town I found that the ABS would kick-back on the peddle just as you came to a halt, which was really annoying, so I used to switch it off when I drove around town etc. I later found out that the sensors just needed a good clean .
Old 01-05-2007, 01:11 PM
  #49
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
Default Re: Brake Package MIKE R maybe??
Originally Posted by lukeytheduke
Hi all, ive serached for this as i know its always talked about but ive found nothing!
Im upgrading brakes sometime this year, what are my options, they need to stop 400-450bhp for road use.
2wd by the way folks
Luke
Luke,
If you have wheels that will take them I can supply a 362mm brake kit using AP discs and rather spunky Brembo 4 pot radial mount calipers for £1375 inc Vat... I have pictures if needed...
muzzman1
30-09-2015 08:59 PM
Sp3no
27-09-2015 07:23 PM
Quick Reply: Brake Package MIKE R maybe??
