Spark plug gap!!!
Old Sep 17, 2004 | 04:14 PM
Hartyboy's Avatar
Hartyboy
Default Spark plug gap!!!
Can someone tell me the gap for the plugs on my series2 RS please!!!
Old Sep 17, 2004 | 04:22 PM
morto's Avatar
morto
hi mate, you did not say what boost your running?
standard boost..0.8mm
high boost.. 30 thou, not to sure what the metric is
best plug for high boost agpr 701c
andy
Old Sep 17, 2004 | 04:26 PM
Hartyboy's Avatar
Hartyboy
At the moment 9 psi but if this sorts the misfire out 12-14psi
Old Sep 17, 2004 | 04:28 PM
Stu @ M Developments's Avatar
PassionFords Creator
0.75mm will do ya
Old Sep 17, 2004 | 04:29 PM
Hartyboy's Avatar
Hartyboy
Cheers mate
Old Sep 17, 2004 | 05:07 PM
KSA-Cossie's Avatar
KSA-Cossie
Would 0.75mm do for 17psi too,mine is set at 0.6mm?
Old Sep 17, 2004 | 06:02 PM
Boost pressure is actually irrelevant..
Id say so, looking at your power output, yes.
Old Sep 17, 2004 | 06:06 PM
KSA-Cossie's Avatar
KSA-Cossie
Ta very much stu.
Old Sep 17, 2004 | 06:52 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
If boost pressure is irrelavant, wot is relvant to plug gaps then please stu?
Is this the same for cossies too?
Old Sep 18, 2004 | 10:34 AM
morto's Avatar
morto
stu i also would like to now as if i use standard plug size on my erst running 15/17 psi it just cuts out on as soon as it boosts? but set at 30 thou on 701c it boosts perfect?
ta
andy
Old Sep 18, 2004 | 10:48 AM
30thou is near as dammit 0.75mm Andy
Std is about 0.8mm i think and thats just slightly too much
Rich,
Only cylinder peak pressures are relevant as one ported head will flow more air at 17psi than a std non ported head as a very very simple example.
Old Sep 18, 2004 | 11:25 AM
CossieRich's Avatar
CossieRich
Thankyou stu.
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
