M3 EVO WOUNT START
Right folks,sold my m3 evo,ment to be going this weekend,had the battery off the past few weeks,put battery on,and know it wants me to punch a code in to the on board computre,to disarm the imobaliser,but i dont have a code,any body else had this problem
cheeRS stu
cheeRS stu
Unknown.
Originally Posted by AJ THE PF GOD
Go to bmw with your logbook etc & they should tell you what the code is providing it hasnt been changed after leaving the factory.
Something along the lines of
"This is a Ford forum, No ones answering you.. there BMW haters!!"
Thats the problem aj,it say,s in owners manual that you can change the code,to one of your own,and im betting some body has at some point
cheeRS stu
cheeRS stu
the dealer will be able to bypass it, it's the sort of thing you'd program in as a backdoor.
might need to get it AA'd to them tho
There is a (time consuming) back door but I cant remember it
It was expalined in the seven series owners handbook but I dont remember seing it in the three
If i remember correctly though the code is set every time you arm it so if it is armed now it is whatever you set it at to arm it.
If the OBC is the full version with the key in position 1 you press ‘CODE’ followed by a number combination of your choice (using the number buttons used to set the clock - up to four characters I tink) then ‘CODE’ again then switch off. The red LED will remain lit indicating it is locked.
To disarm is the same process is followed. If you try to start without disarming the ignition will be dead, the ‘gong’ goes and the OBC just flashes up a warning.
You can use a different code every time you arm it if you want but it means you’ve got to remember it
Sounds like a ball ache but its actually dead easy and quick if you use a simple code that’s quick to enter.
WD
WD
Originally Posted by Mr Brannen
I changed the battery on mine and it never asked for a code,OBC was fine ![Confused](https://passionford.com/forum/images/smilies/icon_confused.gif)
andrewmctiernan
08-09-2015 03:05 PM
