saph cos 4*4 speedo cable
well the worm drive has been replaced with a new item
but its the cable thats fucked
trying to hunt one down as its a ford deleted item SHOCK HORROR
QUESTION ..can i fit the cable with axel stands. or will the car need to be up on ramps
carnt wait to pull the dash out this is going to be fun
not
![Bouncing](https://passionford.com/forum/images/smilies/27.gif)
Easy mate!
I thought it was the worm drive that was a pain in the arse? See, I'm the very opposite of you...I changed the cable when I needed to change the worm and drive
Originally Posted by Stoo
Easy mate!
I thought it was the worm drive that was a pain in the arse? See, I'm the very opposite of you...I changed the cable when I needed to change the worm and drive![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
thats why i asked the garage to fit the worm drive when the car was in
only Ł7.50 from ebay ..so at least its new now anyway
sent a pm to paul @yorkspares to see if he has any.
driving the car with no speedo is major paranoia.i crawl past speed cams
Originally Posted by avid-fan
rstoughy
think it goes into the offside front diff
sure doji said its that side ??
cheers for all YOUR HELP
PM Matt Lewis Ste....
He had loads of 4x4 cables in stock IIRC. Easy enough job & doesn't have to be on axel stands.
Good luck with the dash board
the worst part is getting the cable disconected from the speedo unit.pinch and squeeze
afterwards many fingers bleed
Very easy to do mate try a breakers for the cable give paul a shout in north yorks i got two off him and they proper ford items ...........
Resident Wrestling Legend
is it the 2 peice one of the one peice cable though?
there are 2 sorts, early and late so make sure you get the right cable length
you can also use the same part from the xrx4x4 or the dohc ghia 4x4's
as for teh other end that goes into the front near side, it's screwed into place but you might need to spanner it out as they can be a bit tough to unscrew
also make sure that the cable goes into the square bit of the drive gear otherwise you'll trash it before you've even started
as for the other end that goes into the front near side, it's screwed into place but you might need to spanner it out as they can be a bit tough to unscrew
rstoughy
but on the cos you will probably be able to get to it past the inlet manifodl
if it was a V6 then you'd have to get underneath and start spannering because they are right cunts to undo
and yes, if you have the swoopy 92 spec dash in there, it's nice fun to get the dash out, and even more fun getting things to line up properly afterwards
Originally Posted by The Diva
Steve.....
I`ve got a cable hanging up in the garage mate,just going up there now so give us a shout if you want it....
Piece of piss to fit,takes me about 15 mins....
PM`d you my number....
number stored
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
they are keeping the car till monday now
will ring you next week
regards steve
muz
30-09-2015 08:29 AM
Russ Payne
25-09-2015 08:29 PM
