saff cossise trim removal advice please
hey guys, as above the 2 plastic trims on the left and right side of the rear window on a saff how do they come off??? are they just stuck on or hidden screws anywhere???? also does anybody know where i can get a full new set of window rubbers for the drivers, passenger and rear doors from as mine are a little bit past it any info be greatly recieved as always.......
First remove the rear seat base by undoing the 2 screws at the front of the base near to the floor,then if you drop the seat backs and look in the boot,you will see a 10mm headed nut at the top of each side bolster holding them onto the boot bulkhead.......remove theses nuts and you can then pull out the bolsters and unhook them from the bracket at the bottom...
Once you have removed the side bolsters you will see the holes in the trims where the fixing screws are located..you will also need to unbolt the seatbelt lower strap fixing and thread it back through the trim as you remove it......
HTH......
HTH......
