how to change power steering tank
peace of piss, might be worth draining some of the old fluid anyways
just remove the hose at the bottom of the car under the rad
to bleed it, just keep turning it from lock to lock and topping up
(remember it slides off its mount on the wing )
Resident Wrestling Legend
just make sure you don't get the fluid on any of the car, it just doesn't want to clean off
if you can drain it off first it's much better, then just top it up with the engine off and then run it so it circulates, turn the steerign wheel from lock to lock to bleed it all up properly )
top up to finish and job done
ekjim
17-08-2015 08:57 PM
