Why has my rs got a deadspot/miss fire high rev and load?
Changed dissy cap rotor and plugs but giving like an over boost effect at high revs however also under load.
Also checked Timing and is 12 Degrees BTDC.
Had new Grp A Head gasket few weeks ago and head checked and skimmed.
Any ideas on this one?
Cossiecrew, to be honest plan is too. But i'd at least like to have her running half decent before it goes any where.
In regards to spec.
Exhaust and filter only guys.
In regards to spec.
Right ok
1 - 3 psi
2 - 9 psi
3 - 9 psi
4 - 9 psi
Fuming is an understatement. Just had the head put back on.
Was skimmed, torque down correctly, pressure tested. Valves were not removed when the company skimmed head.
Can my Felpro be re used as it has only done 50 miles or so or would you say new gasket.
It can only be a valve problem?
1 - 3 psi
2 - 9 psi
3 - 9 psi
4 - 9 psi
07-10-2015 12:56 PM
