sorted
Old Apr 12, 2007 | 08:14 AM
martrs's Avatar
martrs
Default sorted
the car will tick over fine and rev up on the spot fine it will drive ok until you put yor foot down and it picks up a little then goes to cut out like it misses then it spluters for a bit the car has cossie management l6 it is as if the spark is not good enough
any help would be appreciated
sorted now it was a earth problem i took the battery of to gharge it up and put it back on but the earth was not on wright tightened it up and it was fine
Old Apr 12, 2007 | 07:37 PM
martrs's Avatar
martrs
Old Apr 12, 2007 | 08:22 PM
Escort_RS_Turbo's Avatar
Escort_RS_Turbo
i had similar problem with mine matey i would look towards boosting/fuelling problems. i had a split boost pipe and dodgy fuel relay so mine was a combo of the 2 but EXACT same symptoms as you
Old Apr 12, 2007 | 08:39 PM
martrs's Avatar
martrs
Escort_RS_Turbo
i will have a look both realys click when ingnition is switched on so i thought they are ok
Old Apr 12, 2007 | 09:13 PM
Escort_RS_Turbo
I suggest maybe checking your boost pipes just to be on the safe side.
Old Apr 13, 2007 | 08:20 AM
martrs's Avatar
martrs
anymore
Old Apr 13, 2007 | 08:24 AM
Coopsrst's Avatar
Coopsrst
Check all your pipes mate.Mine had a slight tear in it .Got it fixed and sorted it out
boeb
Jan 9, 2020 05:11 AM
Fiddy
21
Sep 29, 2015 06:10 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
