cosworth 4*4 cambelt problem UPDATE
Old 08-04-2007, 08:08 PM
SS1
SS1's Avatar
Default cosworth 4*4 cambelt problem UPDATE
a fluid line keeps Appearing on my cambelt ..but its so defined it looks like its been painted on with a brush..ie the line is straight in the middle ????
i wipe it clean with a tissue when the engine is running...but it soon comes back ..maybe a day or two
i think i have a slight leak in one of my lower power steering pipes..there was a drip at the bottom bend of the pipe when i looked yesterday ..
but there is no fluid drops under the car when its parked up...
ANY IDEAS ...it carnt be doing the belt any good
and if it is a leak whys it in a straight line
Old 08-04-2007, 08:18 PM
JjCoDeX75
JjCoDeX75's Avatar
The reason that it is a straight line relates to the cam belt tensioner - if you look at it, you will see that it has a hollow seciton in the middle.
This means that the centre doesnt get wiped off, unlike the sides. My guess would be if it is oil, check the cam cover gasket.
JJ
Old 08-04-2007, 08:20 PM
melzieann
melzieann's Avatar
line is deffo caused by the tensioner
Old 08-04-2007, 08:28 PM
SS1
SS1's Avatar
cheers now to find that pesky leak
Old 08-04-2007, 08:30 PM
Alvyn
Alvyn's Avatar
favorite places cam cover gasket/ 1/2 moons or cam shaft seals!
Old 08-04-2007, 08:35 PM
Kevin B
Kevin B's Avatar
Based on my own personal experiences with a cambelt that came in to contact with oil on a 4x4 Saph (which ended in tears and 12 bent valves!) I would trace the leak and replace the belt asap.
Mine stripped the teeth (of a new ford belt fitted with new tensioner not long before), we think possibly due to an oil leak coming in to contact with the belt, in slow moving traffic pretty much on tick over and it did a lot of money's worth of damage.
Old 08-04-2007, 08:38 PM
SS1
SS1's Avatar
Kevin B
cheers she going in to braided goodridge hoses and a brake flush next week..
so will just place the leak and belt onto the list
thanks again
Old 09-04-2007, 12:21 AM
Check front crank seal as well.
Cam seals are 35/47/7 best fit VITON
Crank seal is 42/56/7 VITON, same as jackshaft.
Old 09-04-2007, 03:10 AM
SS1
SS1's Avatar
cheers
Old 09-04-2007, 10:47 PM
SS1
SS1's Avatar
one last question ..is there anyway to tell if the fluid is oil or power steering fluid on the cam belt ...
gonna ring up the garage tomorrow and book her in ..
and jack up the car and have a look underneath...
on the tissue it looks dark graphite grey when wiped ..
i use silkoline oil
Old 10-04-2007, 06:48 AM
Don't use GOETZE seals(ford) as they are crap get some from a seal place that does them and then ask for VITON(high heat) they are about Ł10 each but worth it.
As for the oil, taste it, engine oil will taste tangy, psf won't.
ps don't get addicted to it!!
Old 10-04-2007, 07:57 PM
SS1
SS1's Avatar
cheers for your help i was under the car tonight ..still carnt see a leak on the engine..
but the power steering return pipe still had a drip at the bottom..
ive wipped it all down..will check again tommorow.
its booked into the garage now.. so heres hoping it is the return pipe
Old 13-04-2007, 09:59 PM
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
If you have no joy, bring her up and il have a look pal.
The PS fluid seap is very common indeed and almost impossible to trace if its on the pipe with the harsh bend in it, which it normally is.
Old 13-04-2007, 10:08 PM
SS1
SS1's Avatar
cheers stu..just did not fancy the drive up to blackpool with the belt getting corrupted with fluid ...
the blokes in roscoes know the onions as sticky paul knows
there upgrading the brake hoses as well ..so get all jobs done in one go
cheers for your reply
Old 13-04-2007, 10:24 PM
mk2rstaff
mk2rstaff's Avatar
mine is doing exactly the same too, so i am concerned now that the oil will eat the belt away, is this the case as it on the outside and just a centre line???????
Old 13-04-2007, 10:38 PM
S3an
S3an's Avatar
is it deffo power steering fluid? maybe you have a crack in your block and its spraying oil in the visinity of the belt. maybe only doing it under running conditions. mind you i dont know much about engines
Old 13-04-2007, 10:54 PM
SS1
SS1's Avatar
Old 13-04-2007, 10:59 PM
frog
0-60 in 17 seconds (eek)
frog's Avatar
Same here, but 16 valves
Found out that there was an oil leak by cyl 1, the head gasket was raised at the corner with what looked like oil build up and oil was seeping through there.
I had a cam belt cover at the time and didn't notice until it was too late
Old 13-04-2007, 11:00 PM
S3an
S3an's Avatar
nice edit lol just a suggestion seriously though doesnt sound good
Old 13-04-2007, 11:19 PM
SS1
SS1's Avatar
K5SSY glad you got it
its not good both fluids will make the belt weak .
Old 14-04-2007, 07:56 AM
mk2rstaff
mk2rstaff's Avatar
how long does this take to wear the rubber away then??????
Old 14-04-2007, 08:00 AM
Alvyn
Alvyn's Avatar
that's like asking how longs a piece of string m8? DO YOU FEEL LUCKY OR UNLUCKY??
It's one of them Questions
ps it makes the belt abit brittle thus more pron to snap rather than wear it out!
Old 14-04-2007, 08:06 AM
mk2rstaff
mk2rstaff's Avatar
ok mate looks like i will be leaving the car alone for now and finding the leak, getting new belt and tensioner. cheeRS
Old 14-04-2007, 08:33 AM
Andreas
Andreas's Avatar
Is it really a fluid line? Perhaps it has been tensioned the wrong way and thereby touching the edge of the thermostat housing?
Old 14-04-2007, 08:34 AM
mk2rstaff
mk2rstaff's Avatar
will look at that too
Old 14-04-2007, 09:43 AM
Ginge !
just finding my feet
Ginge !'s Avatar
im confident that stu wont make a mistake like that,,,, considering its stu's old saph that avid bought
Old 14-04-2007, 11:08 AM
mk2rstaff
mk2rstaff's Avatar
just checked mine and its stopped, i think i got oil on the tensioner when it was off the car, it not touching anything around and the oil has gone away just left a small line, gonna clean that with some meths or petrol then clean it up
Old 27-04-2007, 05:31 AM
SS1
SS1's Avatar
crankshaft oil seal
its all stripped and ready to correct the problem but ford sent the wrong seal and the some of the goodridge hoses didnt fit as well
Old 27-04-2007, 08:40 AM
I am sure the front crank seal is a 42/56/7 so pop along to nearesrt seal place and buy a FAR BETTER ONE, ie VITON HIGH TEMP, ford are crap!!
Old 27-04-2007, 08:54 AM
SS1
SS1's Avatar
thanks for your time but i think the part has now been ordered now ..via the workshop
cheers
Old 27-04-2007, 08:56 AM
Sticky.
Sticky.'s Avatar
crankshaft oil seal
I actually can't believe that mate...Stu had that done before the sale of the car
It's in good hands and will be perfect when back buddy
Old 27-04-2007, 09:35 AM
crankshaft oil seal
Indeed i had. They are garbage as Tabetha says.
Old 27-04-2007, 09:39 AM
Sticky.
Sticky.'s Avatar
Still shouldn't have gone that quick thou surely?
Old 27-04-2007, 09:43 AM
Very common mate, the actual seal system on a Pinto is garbage full stop, tahts why they so commonly leak so much.
Old 27-04-2007, 09:53 AM
AlexF
AlexF's Avatar
ITs a 70s sealing arrangement......
Alex
Old 27-04-2007, 09:55 AM
Sticky.
Sticky.'s Avatar
You learn something new every day
Old 27-04-2007, 10:27 AM
Alex
And not even a good 70s sealing arrangement.
Old 27-04-2007, 11:38 AM
rabmc
rabmc's Avatar
Had the same recently , my half moons were leaking and causing a serious mess , and somehow was leaking down front of engine and ending up with what you had on belt
Old 27-04-2007, 11:46 AM
*Bri.4.b.Cos*
*Bri.4.b.Cos*'s Avatar
Thats what mine was too, only i filed down the housing before realising the tensioner was turned the wrong way
Oh and VITON is the daddy
Bri.
Old 27-04-2007, 12:04 PM
snow*
snow*'s Avatar
I've got a bloody oil leak again from either the cam cover, cam seals or 1/2 moons.
Just had the lot replaced and done 1 track day and now there's oil leaking
Shipping from the U.K to New Zealand aint cheap either
Quick Reply: cosworth 4*4 cambelt problem UPDATE
