quick one
Old Apr 6, 2007 | 03:49 PM
bigal1978's Avatar
bigal1978
Default quick one
diffrence between a normal sierra 2.lt pinoto 205 and a cosworth 205 block whar are the diffrences
Old Apr 6, 2007 | 03:50 PM
Graceland's Avatar
Graceland
Team HOTHOT!
no actual differences between them really, apart from the number stamped into the block where the dizzy is - cosworth blocks have 2222 or thereabouts stamped in - this is to do with the bore thickness and strength - only the best 205 blocks were chosen
Old Apr 6, 2007 | 03:52 PM
bigal1978's Avatar
bigal1978
also what will they rev to standered bottom end cheers
Old Apr 6, 2007 | 03:54 PM
Graceland's Avatar
Graceland
Team HOTHOT!
about 7500rpm with ARP bolts - but don't quote me on that
Old Apr 6, 2007 | 03:56 PM
bigal1978's Avatar
bigal1978
only with the arp bolts ? so a safe bet with none is 6800 ? 7k at a push i have been havin a debate with a guy building a stock car motor but thinks he knows it all
Old Apr 6, 2007 | 04:11 PM
Graceland's Avatar
Graceland
Team HOTHOT!
you obviously need a bit of head work to make it rev past 7k aswell, but again, i'm not sure what it involves - Mike Rainbird does know tho
Old Apr 6, 2007 | 10:47 PM
bigal1978's Avatar
bigal1978
thanks for help
Old Apr 7, 2007 | 08:11 AM
STD bottom end good for 7500 with std rod bolts.
They will all rev higher than this with appropriate cams/ecu, but do then need rod bolts etc .
As said ony selected cores used for the cossies, though 202 blocks are thicker!!
Old Apr 7, 2007 | 12:32 PM
Graceland's Avatar
Graceland
Team HOTHOT!
202 blocks may be thicker but they were used for the block on Transit diesel's
Old Apr 7, 2007 | 04:11 PM
I always thought the 202 was a odd pinto block ?
Old Apr 7, 2007 | 04:19 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I used a normal Sierra 205 block for 8 years before it cracked.
It did have the cossie crank, rod and pistons in it but otherwise was a standard 205 block.
Was running at least 280bhp all that time and died after running about 340bhp for 2 years.
Steve.
tankybaby66
Feb 6, 2016 02:24 PM
locum8
Oct 1, 2015 01:50 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
