Quick brake question
Old Apr 4, 2007 | 10:55 PM
Rippers's Avatar
Rippers
Monte Geek
Default Quick brake question
When I drive the Esc the first touch of the brake pedal seems to drop an inch.. then its ok.. Whats that all about? bleeding prob?
The pedal feels hard in general not sure if thats a good thing or not?
AP 6pots btw
Old Apr 5, 2007 | 06:03 AM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
pad knock off?
Old Apr 5, 2007 | 07:40 AM
As above or sticky sliders.
Old Apr 5, 2007 | 08:27 AM
Rippers's Avatar
Rippers
Monte Geek
Whats that mean guys
Old Apr 5, 2007 | 10:12 AM
Micky The Finn
Former Sponsor
sticky sliders?on ap calipers that dont have sliders?
Old Apr 5, 2007 | 10:14 AM
GARETH T's Avatar
GARETH T
who said the problems with the front? (more than likely is)
Old Apr 5, 2007 | 10:16 AM
Rippers's Avatar
Rippers
Monte Geek
So whats pad knock off?
Old Apr 5, 2007 | 10:17 AM
GARETH T's Avatar
GARETH T
if a disk isnt running true, and the pads are being pushd (knocked) back a little bit
Old Apr 5, 2007 | 10:19 AM
NUTS RuS's Avatar
NUTS RuS
Bought some stolen pads Paul ?
Could be related to m/c size now needing to push more fluid
Micky The Finn
Former Sponsor
sticking rear sliders,or even fronts for that matter would not create these symptoms though would they?
particularly if ony standard rears but 6 pots fronts,why there are so many folk on here at the moment giving folk false or missleading advice is beyond me!
Rippers's Avatar
Rippers
Monte Geek
What can be done to rectify that?
Old Apr 5, 2007 | 10:22 AM
Micky The Finn
Former Sponsor
exactly,common cause on ap kits modified on to standard uprights is the disc running out of true and instead of the pad moving of fractionally when the peddle isnt pressed they get "knocked" back further by the disc not running true,the same thing happens if you go over a very bumpy section of road,
Old Apr 5, 2007 | 10:24 AM
Micky The Finn
Former Sponsor
use group A uprights so your caliper and disc are bolted on properly,
or what is done on most group N rally cars is stronger springs behind the pistons,evo's suffer really badly from this even on standard calipers.
Old Apr 5, 2007 | 10:26 AM
GARETH T's Avatar
GARETH T
you are right,, you wouldnt get free play in the pedal from it
clock to see how true your disks are running! also do your brakes judder under hard braking?
Old Apr 5, 2007 | 10:32 AM
GARETH T's Avatar
GARETH T
play in wheel bearing,,,
and bleed fuck out of them,, just incase
Old Apr 5, 2007 | 10:33 AM
Rippers's Avatar
Rippers
Monte Geek
TBH they are perfect other then that.. I've done less then 1k miles on them. It feels like fluid movement on the pedal rather then a click.
Maybe its where I'm used to my Beemers brakes and these AP's bite a lot earlier?
Also I did bleed my front brakes recently but not the rears could that be related?
Old Apr 5, 2007 | 10:36 AM
GARETH T's Avatar
GARETH T
you lazy man,, you can bleed the rears without taking a wheel off
Old Apr 6, 2007 | 12:14 AM
JjCoDeX75's Avatar
JjCoDeX75
This is what it was in mine about a year ago when I had the smae problem
JJ
Old Apr 6, 2007 | 12:31 AM
SS1's Avatar
SS1
does the car still have to be level to bleed the brakes ..
i had the same issues with my old d reg rsturbo ..
if you jack the car up to bleed the brakes it wont work ..
something about load compensator issues
the car has to be flat level to bleed the brakes ..
155lee
Oct 27, 2015 04:55 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
Bransby
Sep 11, 2015 01:09 AM
focus2351
Sep 9, 2015 09:33 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
