Any difference between 2WD and 4x4 plenum chambers???
Is there any difference between 2wd and 4wd plenum chambers?
I know the later EEC escort ones are different but were they changed on the weber equiped cars?
If so, what are the differences?
Originally Posted by Graceland
the 4x4 plenumn has a bolt on elbow for the throttle body where the 2wd version is cast into it already iirc
Originally Posted by JonnyBravo
Why do people switch to a 4x4 plenum around 450hp then ?
Surely the escort cosworth plenum is just the better one to use ?
Due to the elbow I guess mate, personally I would go for the eec one though if bothering to swap.
Well I'm hoping for around 450hp, I did read something MikeR put about not over speccing stuff.
He said that the 4x4 setup was better for around that h/p then anymore you would want the eec iv.
I presume there is nothing useable from the 2wd manifold if I went down the route of using either of the other manifolds ?
The difference is in the throttle elbow and thats where the restriction comes from. You can open this up by having a plate welded on the outside and cutting away the rest, this with a plenum spacer and its good for over 500bhp.
Escort ST one is good if dont want more than 480bhp, trying to find one is the fun part though.
Does the 2wd throttle body fit the 4x4 and EEC IV plenums ?
FlashRS
13
Aug 31, 2015 06:02 PM
Marc sierra
12
Aug 30, 2015 10:38 AM
