2wd g/box question
wounder if anyone can tell me is there something thats missing that should sit on the left side of this pic of bellhousing?
wanna make sure everythings where it should be before i install box
also has anyone got a 2wd gearstick at all??
thanks in advance
thanks in advance
![](https://img.photobucket.com/albums/0703/RACE-SPEC/apr1010.jpg)
Team HOTHOT!
on the left side where the square is with the dot, there should be a nipple type fitting that the clutch release arm sits on to stop it flapping about
Crappy design it is, you can dril through the hole and use a nut and bolt through hole sandwiching the arm between them, stops the aggro and rattle.
ps i got a brand new gearstick, and housing on the bay, with brand new leather gearknob for £22, might be worth a search
Originally Posted by RONNIE AMIS
i drilled through and used a 8mm nut and bolt to hold the end of the clutch release arm, thats all i can see missing, you will need a 3 door cradle their different to the saph one's, ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Originally Posted by Dan@FastFord
im about to order said part off DOO so i think they may still be available lol
Be interesting to know if you get 1
Baby Cheesus
well i ordered all the bits i need earlier, and should get them weds ish, so ill let you know! ![Big Grin](https://passionford.com/forum/images/smilies/icon_biggrin.gif)
Originally Posted by T S M
the 3 door type was soon modified to the sapphire type as the arm wore the gear box away.Try wood ford for the sapphire clutch fork nylon retaining clip/bush.
has anyone got a spare retaining clip for the fork cant really compence with engine install unless this is sorted
oh how the little things give you big grief
andrewmctiernan
08-09-2015 03:05 PM
