Escort Cosworth Help!
aye its easy... just put wheel on full lock so u can get your whole arm/shoulder under the arch to reach.
its a twist-to-lock connection so grab the bulb holder and twist then tug, dont just tug till you break it... lol
difficult to remove mate, put a thin flat screwdriver in half way along the top of the indicator and push the lug upwards, thats all that retains it in place.
should pull out then, they are very dame tricky
arches in the way?
put your arm up infront of the arch then may need to jack front up in oder to get your arm in a opsition that you can slide it up without dislocating it tho
This is the correct way to remove it.....although I use a thin piece of plastic
Jim he has Arch liners in the way of getting from behind
altho im sure that wen i changed a bulb on a mates esccos it was a total peice of piss and i didnt have any problems... maybe he had the arch liners removed for some reason?
Originally Posted by Skiman
does the glass bit beside the indicator have anything to hold it on?mine kinda could fall off....??
Well i just stuck me hand up like jim said twisted and out she came then poped it back in took 2 mins no removing nothing and me arch liner was in the way go round it.I am talking about the side with the water bottle there too.Im used to working on renault 5 turbos tho
jessie_rs
11
03-06-2019 04:57 PM
