Wasted spark problem SHE BLOODY RUNS!!!!!!!!!!!
Old 30-03-2007, 06:36 PM
  #81
Roosie
500bhp Cosworth in making
Roosie's Avatar
still cant find earths tho but pretty sure i never took any off
Old 30-03-2007, 06:38 PM
  #82
Graceland
Team HOTHOT!
Graceland's Avatar
Roosie - Don't forget to REMOVE the surpressor that is connected to the 2 green wires in the picture above and link the green wires together (solder them and tape them up)
Old 30-03-2007, 06:42 PM
  #83
Roosie
Roosie's Avatar
before
after
Old 30-03-2007, 06:44 PM
  #84
Roosie
Roosie's Avatar
really i want my old std chip back thats at msd as i can eliminate anything to do with that and the closed loop setup.
Old 30-03-2007, 06:47 PM
  #85
KSA-Cossie
KSA-Cossie's Avatar
Take it you haven't got a hold of stu yet ?
Old 30-03-2007, 06:48 PM
  #86
JTECH James
Passion for Fords!
JTECH James's Avatar
anyone near to you with another cossie, you could try the ecu from that?
Old 30-03-2007, 06:50 PM
  #87
Roosie
Roosie's Avatar
nope there all 2wd`s stuck in a right hole now
just spent Ł600 on new bits and the car dont run
no rang 3 times then the 4th they were shut
Old 30-03-2007, 06:52 PM
  #88
JTECH James
Passion for Fords!
just chill
stu will sort it ,you know he will.
could be something simple
these things happen
Old 30-03-2007, 06:54 PM
  #89
Roosie
Roosie's Avatar
Originally Posted by JTECHSAFF
just chill
Stu will sort it ,you know he will.
these things happen
this is the first problem with this car running wise its always run perfectly dont know why i even got wasted aprk as ive never had a misfire
Old 30-03-2007, 06:55 PM
  #90
JTECH James
Passion for Fords!
it will be worth it mate,
just hold fire till you have spoken to stu
Old 30-03-2007, 07:03 PM
  #91
Roosie
Roosie's Avatar
has anyone got pics of were there earth wires are one there inlets?
Old 30-03-2007, 07:05 PM
  #92
JTECH James
Passion for Fords!
the main one on my inlet manifold bolts to the rear bolt against the bulkhead
Old 30-03-2007, 07:14 PM
  #93
trevCOSS
trevCOSS's Avatar
do all 4 plugs spark when you turn the ign on? could be one of the amps is duffed, Mine also sparks when I turn ign on! often fires whatever is left in the engine, however it still starts fine after this initial little fault
Old 30-03-2007, 07:15 PM
  #94
Roosie
Roosie's Avatar
hope not there brand new
Old 30-03-2007, 07:16 PM
  #95
Roosie
Roosie's Avatar
ill check later in a little while if they all spark ok
Old 30-03-2007, 07:18 PM
  #96
trevCOSS
trevCOSS's Avatar
also have you tried swapping the leads as in move lead 1&4 to lead 2&3 and vice versa? mabe could have them the wrong way round
Old 30-03-2007, 07:20 PM
  #97
Roosie
Roosie's Avatar
no
all my leads are marked 1to4
and my coil has 1to4 on it so i matched them up
  #98
Roosie
Roosie's Avatar
and put 1 closets to timing end
  #99
trevCOSS
trevCOSS's Avatar
try swapping them as I indicated
Old 30-03-2007, 07:21 PM
  #100
Roosie
Roosie's Avatar
surely that would do engine no good
im sure there be marked for reason
Old 30-03-2007, 07:23 PM
  #101
JTECH James
Passion for Fords!
try as trev says, he cocks things up alot
joke btw
  #102
trevCOSS
trevCOSS's Avatar
I have now fitted 4 of these conversions depending on who made the sub loom the leads may need to be opposite, as for doing the engine harm, it doesnt work now so if you swap them and its not the problem it still wont work
Old 30-03-2007, 07:25 PM
  #103
Roosie
Roosie's Avatar
ryan made my loom
  #104
trevCOSS
trevCOSS's Avatar
thanks james
Old 30-03-2007, 07:29 PM
  #105
trevCOSS
trevCOSS's Avatar
Originally Posted by Roosie
ryan made my loom
good he made mine to, Its up to you you can try if you like or dont try if you dont like, just as stated I have fitted a number of these conversions and at some point MSD changed which wire goes to which pin on the ecu to fire which cylinder, if this is not changed on the sub loom to match then the leads will be wrong. Im probably wrong but it wont do any harm to try and if im right you'll thank me.
  #106
Roosie
Roosie's Avatar
i will try in a min mate ill try anything at min
Old 30-03-2007, 07:30 PM
  #107
JTECH James
Passion for Fords!
it cant do any harm if it fires on the exhaust stroke anyway
its not as if the car will actually start if its wrong
Old 30-03-2007, 07:31 PM
  #108
the original
the original's Avatar
Hi Roosie
do you live in thetford? I am up the road at attleborough
Not being big-headed but I expect I can get to the bottom of this for you
except I am flat out until after the 'ring trip
I guess you want it going sooner than that?
Old 30-03-2007, 07:34 PM
  #109
Roosie
Roosie's Avatar
hi mate well if it aint sorted out by the time your free your welcome to come have a look are u fairly clued up on cossies?
Old 30-03-2007, 07:35 PM
  #110
Stavros
DEYTUKURJERBS
Stavros's Avatar
PROOF that modified cars are shit
The minute you mod any car its fucked, even my mondeo, took out the old headunit and its been a nightmare ever since
Old 30-03-2007, 07:36 PM
  #111
Ryan
Ryan's Avatar
the loom is wired for the later driver.
roosie you got a terminal tester?
Old 30-03-2007, 07:37 PM
  #112
trevCOSS
trevCOSS's Avatar
ok ignore my advice as ryan has confirmed its ok for the driver you have
Old 30-03-2007, 08:18 PM
  #113
Roosie
Roosie's Avatar
ok right i have hardly any spark at all when i turn my ignition on with or wothout ecu connected it does one strong spark and then thats more or less it then when i turn igntion off it does another one
my light now stay on even if i take the ecu off.
yes i have a circuit tester dont really know how to use it
Old 30-03-2007, 08:20 PM
  #114
Roosie
Roosie's Avatar
and also i do have a earth at the back of inlet manifold
Old 30-03-2007, 08:38 PM
  #115
Ryan
Ryan's Avatar
roosie give me a call on 07919537128
i'll take you through a few things
Old 30-03-2007, 09:14 PM
  #116
The DIVA
The DIVA's Avatar
Roosie.....
You mention the fuel reg making a noise ?
This is the noise of the fuel pump running,it should stop after about 8-10 seconds of switching the ignition on,if it doesn`t this signifies the ECU is in fault condition and it`s possible the chip isn`t working....
This happened with my first closed loop chip,there had been a small software fault that had not written a certain piece of info,the car would not start and the pump was running continuosly,Stu sorted it out straight away,burning a fresh chip...
Ring him in the morning,he will sort it no problem.....one thing MSD do have is perfect customer service.....
Old 30-03-2007, 09:28 PM
  #117
Ryan
Ryan's Avatar
just spend about abotu 30 mins on the phone with roosie, went through pretty much everything,
and i think its as you mention diva, he pump run's constantly on ignition.
It gets good spark on 1&4 but only a mild spark on 2&3, so i thought it was either a wiring or amp fault, but he swapped amps and check continuity on all the coilpack wiring and its fine.
so will wait to see what happens when he speak to stu.
Will be sorted though
Old 30-03-2007, 09:33 PM
  #118
Roosie
Roosie's Avatar
cheers ryan
yeah my fuel pump just want to run all the while it might stop for 2 secs then comes on again
will ring stu in morning thought he may have seen this post allready
Old 30-03-2007, 09:37 PM
  #119
ECU Monitor Enthusiast
Roosie,
If all else fails, I am going to Skegness on Wednesday/Thursday.
Thats not too far out my way to where you live.
See how it all pans out
Old 30-03-2007, 09:45 PM
  #120
Roosie
Roosie's Avatar
which way do u go to skeggy i live righ tby a11!
ill keep everyone informed
Quick Reply: Wasted spark problem SHE BLOODY RUNS!!!!!!!!!!!
