does ecus have numpers for pins
The pins are not normally numbered on the loom plug.
With the ecu loom plug holes looking at you and the longest row on top,
(The loom wire should be on your left hand side)
Pins 1 to 18 go from left to right along the top longest row
and
19 to 35 go from left to right along the bottom shortest row.
(cossie I presume )
and
(cossie I presume )
Originally Posted by JTECHSAFF
mine has numbers inside the loom plug
from AMPHENOL who make it and they dont have numbers on them.
You are one of the lucky ones then I guess
Passion for Fords!
whoooooooooooooooooooooooaaaaaaaaaa
ive never been lucky with the cossie before
PassionFords Creator
Originally Posted by Roosie
Stu i have your instructions for the closed loop wiring for lambda but need a end connector for the pin to goto the ecu were can i get one?
Is yours 4x4? if so, it allready has teh wiring for teh lambda as standard.
JJ
Is yours 4x4? if so, it allready has the wiring for the lambda as standard.
or my old std chip
so my 4x4 will have the loom for lambda even tho its a 1990?
never even got chip box
or my old std chip
or my old std chip
Yes, the 4x4 has the wiring as standard mate. Thats saved you a job hasnt it.
Did teh ecu you sent have a chip in then? I will ask Kenny what he has done with it mate.
yes mate cos i bought the closed loop dhip and driver for wasted spark.
sent u whole unit with std chip lol if u cant find it dont worry.
hasnt really saved me a job as i bought a bosch universal sensor but may just get a cosworth item to save time and sell my lambda sensor
muz
30-09-2015 08:29 AM
