FAO mr rainbird,rapidcossie or other people with std airbox
Old 29-03-2007, 02:39 PM
  #81
Chip
*** Sierra RS Custard ***
Chip's Avatar
Originally Posted by dovboy
if its 40 deg,why bother with nos
Nitrous isnt just useful for its cooling effect, see this months fast ford for more info in the "N is for nitrous" section
Old 29-03-2007, 02:41 PM
  #82
dovboy
dovboy's Avatar
but it is used for its cooling effect as well as other things
Old 29-03-2007, 02:42 PM
  #83
Chip
Chip's Avatar
Its cooling effect is best described as a useful side effect.
Old 29-03-2007, 02:45 PM
  #84
dovboy
dovboy's Avatar
oh ffs,ok then have u noticed phil on a very cold night that a turbo car especially ,goes better?
Old 29-03-2007, 02:51 PM
  #85
Chip
Chip's Avatar
Did you just use the word "Phil" in a sentance about noticing something for himself, not repeating someone he thinks he understood?
Surely not
Old 29-03-2007, 02:54 PM
  #86
dovboy
dovboy's Avatar
Surely not
Old 29-03-2007, 03:03 PM
  #87
rapidcossie
rapidcossie's Avatar
Originally Posted by CossieRich
Does having the standard air box actually make much difference over a cone filter? I have my air box sitting in the garage doing nothing.
think you can get cooler air in with a airbox compared to a cone filter.
cant be bad. euan have done 485 atw with one
im sure it is good, but has anyone doen a test with a cone filter and then a standard air box?
Rich...we cant keep the air box cool never mind a cone
Old 29-03-2007, 03:05 PM
  #88
rapidcossie
Originally Posted by Bosch Dealer
...this old chestnut
The air box is as stuffy as a cone and more restricted...i would want more AIR..hence i only choose cone.
Thats why we have a decent intercooler guys to cool that air from the turbo.
Remember the optimum air charge temp is 40c..you will get the best out of your engine at that
the air box only becomes a restiction at a certain power level.
99% of people on here are not at that power.
Rod uses a cone beacuse he is WAY past it. Rods inner wing is cut out and the filter area is totally sealed when the bonnet is shut
It has ben tested and res tested on my car.
  #89
Garage19
Garage19's Avatar
As said its not from ME..but from a proper pro I bet it really irritates the book worms i am blessed with such knowledge...40c is where its at for optimum power on a YB.
Whats your view on this Mike as you know the person who told me
Yes Phil, thats right, 40 degrees no matter what turbo is fitted, no matter what boost its running, irrelevant of cmpression ratio and nothing to do with what AFR its running.
They ALL work best at 40
You didnt misunderstand anyone at all, physics really is that simple
What on Earth are you banging on about Chip?...if you can get 40c air charge temps no matter what spec you will have the optimum burn...so please stay off the books.
Phil,
Have you never seen an EGT gauge before?
Do you not think the AFR would have more of an effect on the burn temp than the intake charge temp??
Old 29-03-2007, 03:07 PM
  #90
rapidcossie
Originally Posted by Rick
childish question - does chatter totally dissapear when you run an airbox?
No..i still get the chatter noise but its no where near as loud.
Old 29-03-2007, 03:12 PM
  #91
dovboy
dovboy's Avatar
euan ,my plan was to put an alloy shield up to block the cone away from heat sorces.
thought about then gold plating it as i have heard that gold is good at reflecting heat.
(air in through the inside twin headlight)
good idea? i'm allways thinking of pish like this that might or might not work
  #92
rapidcossie
Again just for the people that think a cone cant suck cold air while the car is moving...
The side of my airbox is actuaually melted from the air that surrounds it.
This proves that the air surrounding your cone is VERY hot.
We have tested all this on my car.
Old 29-03-2007, 03:13 PM
  #93
pete mcrash
saff is working!!!...atm
pete mcrash's Avatar
i'm going to put mine back on.....my pal has found it in his garage.......cant do any scientific test........ but will see how it feels....hope it dosn't feel better.........like the cone noise.....
Old 29-03-2007, 03:16 PM
  #94
Chip
Chip's Avatar
Seems like a harsh thing to say about the old cunt
  #95
pete mcrash
Euan.........do u think the size of ur turbo makes a difference......smaller turbo,less heat.........
Old 29-03-2007, 03:21 PM
  #96
Deleted by Request
Former Sponsor
Deleted by Request's Avatar
...wannabe tuners its not hard to understand that 40c is the best temp for fuel atomisation..and i thought you was knowledgable..especially you Chip
Old 29-03-2007, 03:22 PM
  #97
Chip
Chip's Avatar
Phil, you are correct its not hard to see that 40 degrees is good from that point of view.
Its just harder for the rest of us to TOTALLY IGNORE the rest of the picture with regards to air density and detonation characteristics that a change in temp also effects.
You hear one little fact, stick you blinkers on, and ignore all the other aspects.
Old 29-03-2007, 03:30 PM
  #98
big_wig_074
big_wig_074's Avatar
odd,and im not arguing with anyone here,but i changed from a cone filter to my old airbox one day (as i beleived the hype about heat soak.)with the 400bhp engine and the damn thing wouldnt run right,PROPERLY restricted!!!it felt like it was hitting a brick wall.all i changed was the airbox.as soon as the cone went back on it flew again. was like hitting fuel cut as soon as the boost cut in etc,just not as harsh.
Old 29-03-2007, 03:33 PM
  #99
Deleted by Request
Former Sponsor
...chip i know mucho about every aspect of the YB and here i was stating one fact..ignore the other factors around it the point is i was RIGHT and yet you choose to argue
Old 29-03-2007, 03:38 PM
  #100
Stavros
DEYTUKURJERBS
Stavros's Avatar
Phil, your wrong.
About your YB tuning knowlege AND this.
Im never sure if you really believe you know everything or just go on an on like this just to wind people up.
I guess both.
An engine builder and a tuner are two wildly different things.
And you are neither it seems.
  #101
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
I think you will find that is from when you slow back down to sensible speeds and the airflow is reduced, but the turbo is still recovering from being at 850°C . The radiated heat in this scenario is absolutely IMMENSE.
  #102
Franco
Franco's Avatar
Sod this Phil, Answer ya pm's!!
Old 29-03-2007, 03:39 PM
  #103
Chip
Chip's Avatar
No Phil, you arent right, becuase when deciding on what will make the most power on a YB or any other engine you cant just choose to ignore a load of factors.
The fuel mix will be even better at 100 degrees than at 40, so do you think that will give yet more power?
In fact why dont you go even further and route your exhaust through the intercooler, that will REALLY get that fuel to avoid dropping out!
Old 29-03-2007, 04:16 PM
  #104
foreigneRS
Testing the future
foreigneRS's Avatar
this thread is brilliant
Old 29-03-2007, 04:23 PM
  #105
Bullett
Bullett's Avatar
i see this is gonna be a big divide between people.and it always will
oh well heres the front of mine with the morette out of the way.
the big holes go all the way up the underside of the box but not on the turbo side.
Old 29-03-2007, 04:24 PM
  #106
Deleted by Request
Former Sponsor
...........40c is where its optimum....nothing more to say.
Stavros a special shout out to you as i hear you write articles...i just hope they aint technical as you certainly know less than me Judging by your recent replies on here?...Lets hope its me thats the Dreamer Steven
Old 29-03-2007, 04:29 PM
  #107
big_wig_074
phil: 40 degrees is the optimum temp for what though?the air?the fuel?at what point?as the air will be different temps before turbo,in turbo,after turbo,in intercooler,in plenum,in engine with valves open,in engine as its being compressed,in engine as it has been compressed.im not arguing,genuinely interested in at what point you need this 40 degrees?
Old 29-03-2007, 04:32 PM
  #108
Deleted by Request
Former Sponsor
FUEL ATOMISATION
Old 29-03-2007, 04:41 PM
  #109
big_wig_074
that doesnt answer my question phil.i dont know the answer so i asked.
Old 29-03-2007, 04:50 PM
  #110
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
FUEL ATOMISATION
so why is fuel atomisation better at 40c than 35c?
Old 29-03-2007, 04:53 PM
  #111
foreigneRS
Testing the future
foreigneRS's Avatar
if the fuel doesn't atomise at less than 40 deg. C then you have shit injectors
even if it is the best for fuel atomisation, it doesn't mean it's best for power. if all of the fuel doesn't atomise to get a burn with the 'best' AFR to get most power, you would just inject more fuel until it does
how difficult is it to understand that the more air you get in a cylinder fill, the more fuel you can put with it to get the most energy out?
quite simply, colder air is more dense and has more oxygen per volume (which is the limiting factor in an air pump) than hotter air. that is simple physics and cannot be seriously argued against other than by a total clown.
and that is ignoring any effect on reduced detonation risk of lower ACT's that may allow better ignition timing for more power
i don't know why any of us are wasting our time typing really - god has spoken
Old 29-03-2007, 04:59 PM
  #112
col cos1
col cos1's Avatar
hers mine,out with the cone and in with the box......
Old 29-03-2007, 05:00 PM
  #113
Deleted by Request
Former Sponsor
..i am only making a fooking true point no need to get all pedantic!..Really,you lot ought to know better
German bloke now
Old 29-03-2007, 05:14 PM
  #114
foreigneRS
Testing the future
foreigneRS's Avatar
you're such a cunt cos i never know when you're serious or not
Old 29-03-2007, 05:41 PM
  #115
capri-rs
capri-rs's Avatar
have to say. this is the best topic i have started so far
Old 29-03-2007, 06:59 PM
  #116
rapidcossie
it will work a treat Dov as thats what i have now..not gold tho
Old 29-03-2007, 07:00 PM
  #117
rapidcossie
he may be old but wouldnt say he was past it
Old 29-03-2007, 07:01 PM
  #118
rapidcossie
i did notice a increase in under bonnet temps after i fitted the T4.
Old 29-03-2007, 07:18 PM
  #119
kjc300
kjc300's Avatar
Old 30-03-2007, 05:47 AM
  #120
cressy
cressy's Avatar
so to sum this one up a 90qwid group A filter is a waste of money and just modifi your standed airbox
anyone want to buy a new group a filter cheap or will px for standed airbox
Quick Reply: FAO mr rainbird,rapidcossie or other people with std airbox
