Question for engineering machinists..........
Old Mar 26, 2007 | 09:09 AM
CosRush's Avatar
CosRush
Default Question for engineering machinists..........
What is the easiest way to shape the underside of a flat lambda type boss for an exhaust so that it mates with the radius of the pipe???
Its actually for an EGT sensor, but the principle is still the same.
Any help???
Old Mar 26, 2007 | 10:08 AM
CosRush's Avatar
CosRush
Like this..........
Making B from A.............
Old Mar 26, 2007 | 10:36 AM
gingeRS's Avatar
gingeRS
you could use a ball nosed cutter but i doubt you'd get one big enough, on a mill
you could cnc it, but would take alot of programming
you could mount it up on a faceplate on the lathe and cut the radius with a large drill
or grind it by hand (my suggestion)
Old Mar 26, 2007 | 10:42 AM
CosRush's Avatar
CosRush
Cheers Ginge
I'll probably grind it by hand then
Old Mar 26, 2007 | 10:51 AM
gingeRS's Avatar
gingeRS
Originally Posted by CosRush
Cheers Ginge
if its not too big, you'd get a better finish by filing it carefully with a curved face file (radius will be similar to the exhaust)
Old Mar 26, 2007 | 10:54 AM
CosRush's Avatar
CosRush
Yes true , although it is stainless...........
I hate stainless nice to look at hard to work with by hand........
Old Mar 26, 2007 | 10:56 AM
trotty's Avatar
trotty
the best way i'd say for a 1 off is to mark up the radius required with a scriber,then with a half round file shape it to suite. if it was 10 off i'd say cnc machining all the way.
Old Mar 26, 2007 | 11:02 AM
CosRush's Avatar
CosRush
Originally Posted by Matt J
I thought lambda boss's sat in the hole with an outer flange to weld around? so no need to shape it to fit thats how mine worked.
Not any ive seen, mine isn't, besides its an EGT sensor rather than a Lambda so is alot smaller........
bigryrs
Mar 28, 2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
Anutternutter
24
Aug 31, 2015 01:24 PM
Marcus L
Aug 29, 2015 02:18 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
