FTAO internaly gated GT30 owners
How do you find the turbo performs? what sort of boost threshold does it have? and what sort of power/pressures are you running? anyone had reliablity issues?
I have a GT3076r with internal gate, APT`s ultimate internal gate in stead of the original garret one. Have high expectations for it, but havent tried it yet.
Originally Posted by Bosch Dealer
..i dont think anyone recommends you run a GT series turbo on a yb without it being external wastegate.
A mate's Dad who has a MAD tuned Escort Cosworth has just fitted up an internally wastegated GT30, recommended by Mark!
hi will the one on my car i cant really tell you anything because i haven't gave it any abause at all i will, once it's live mapped i dont have any serge issues when it comes on boost
it makes boost about the same time as my t34 with .63 but kicks twice as hard i have heard rumours they they do suffer from cracking the rear housing .............im not really botherd about that as long as it lasts a good while im happy nothing lasts for a long time in motorsport anyway i forgot to add the internal wastegate wont make as much power as the external one ..
the internal one is not as laggy as the external one, horse for causes and all that
you will have to show me next time at the RSOC meet at the greyhound mate, I was going to say hello Tues night, but I didn't get chance . Car looked stunning though. , although you might need to upgrade your brakes
You recon the GT30 is a good compromise then? thinking when I rebuild my escort it might be getting one
will there was cossie parts flying all over the shop myself and steve talking cossies all night (sad i know) did you notice why the back end was so high ? i couldn't be botherd to lower it because these are off the rs2000 mk5 and i dont want to mess about with the hight fitting them back on the rs2000 .........lol... i could do with bigger brakes my others have gone in for re-valving should be back next week
thought it was just the stance, usually see 3 doors/saffs sat about "1 higher at the back for the handling people slam them on the deck then wonder why they understeer into oblivion
what are you after?
my gt30, made just over 500 bhp on road fuel on a engine dyno, @ 26 psi.
hits 30psi by 4000 rpm, and i still havent played with cam timin to improve that.
Originally Posted by Fiecos Dan
what are you after?
what are you after?
mind does not hit 30psi @ 4000k far from it , i wont know untill it's finally mapped
what are you after?
Marco...why do you have a dipsick in your slam panel?
Me and my Dad are just fitting one to his Escort Cos then it will be off to M.A.D for mapping so I will let you know how it gets on
Wil is right i use a 7.5 litre gated system touring car sump and if i leave the dip stick in it stops one of the gates from opening , i just use another cut down dip stick and a dummy
marco
Originally Posted by Rick
30psi at 4k is less than a t34 63 makes surely?
rick i dont know but when the boost comes in i only know from 1st if you know what i mean my t34 with the .63 use to start making boost @ 3k and this turbo does the same in 1st gear it comes on boost about 3k well it's making power it's hard to explain
marco
