Wide band lambda sensor
Old Mar 22, 2007 | 10:14 PM
AndyKam's Avatar
AndyKam
Default Wide band lambda sensor
Can you get one to fit into the lambda sensor hole in the exhaust housing of a T34?
Old Mar 22, 2007 | 10:29 PM
The DIVA's Avatar
The DIVA
The Bosch one uses the bigger boss,not sure if there is any others with the smaller fitting but i doubt it....
GARETH T's Avatar
GARETH T
most wideband are m18 x1.5 and i think the threas your on about is m14,,, so no
but i think bosch motorsport got a small threaded wideband,, but i dont know alot about it
Old Mar 22, 2007 | 10:40 PM
AndyKam's Avatar
AndyKam
My T34 is on my L6 managed CVH Fiesta Turbo so the lambda sensor isnt used. I want to fit a air/fuel ratio meter and rater than weld in a seperate thread it'll be good if I can find a sensor that I can just screw into the T34 thread.
Old Mar 22, 2007 | 10:45 PM
GARETH T's Avatar
GARETH T
i would honestly weld in a boss,,, as then yuor tuner could use it aswell
Old Mar 22, 2007 | 11:07 PM
GARETH T's Avatar
GARETH T
just checked,, the new bosch wideband is M16 x 1.5
Old Mar 24, 2007 | 12:59 AM
AndyKam's Avatar
AndyKam
Cheers mate. Do you know where I can get one from? Are you sure the T34 fitment is M14?
Old Mar 24, 2007 | 08:23 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Is there enough meat around the existing hole to dril and tap it out to m18?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Cosnada
Jan 7, 2016 05:30 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
