What rear cosworth beam is actualy best?
Im confused reading some of the threads on beams
Theres different versions from Zoo
Adrenaline now do one
Ahmed.
Whats actauly the best for a road going track car (only about 4 trackdays a year).
Also would have to be good on very rough country roads!
Ahmed.
Originally Posted by Bosch Dealer
Without a doubt Ahmeds,THE ORIGINAL AND BEST.
I'm happy to put mine forward if a mag wanted to do a non bias test. I know mine are 100% quality and I'm sure the other 2 are top quality.
I run a ZOO beam,which is adjustable for camber and toe,the one you will need is the rally spec strapped beam if you run on bad roads,give Brom a ring as he is now set up to make them again....
The original and best is the beam he copied it from - probably a WRC item...!
.....Pon its in the name Ahmed Bayjoo...you cannot argue with that....the others may be good but name counts for alot IMO.
Originally Posted by The Diva
The Ahmed one i was offered a couple of years ago was no where near as good as the ZOO beam,not sure if he has changed the design now,Ahmeds only had camber adjustment
saff is working!!!...atm
i'm a big A.B fan..........but he charges a grand.......and as said u can do more with the others........i'm after one....time will tell who's i buy
...you get what you pay for.
....this thread was destined to fail..until i joined the party![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
just the welding different on them.
and the rest is down to setting the beam correctly for your use.
dave,ahmeds one is based on a proper built car made for a variety of terrain...ala grp a/wrc...all the others are copies...bit like most of the chip software....ahmed started all the maps the others copied and just tweaked to make it look like there own
nearly.
they are still going to adjust the same etc....
...yes i agree Dave but to a layman its all about name...you got 3 people who make beams...but you only heard of one...Ahmed the biggest name in cosworth IMO...who you gonna trust?..Its an important piece of your car...
....this is no disrepect to the other people out there i just speaking the truth.
Me personally would certainly look into Dannys beam too
Caraholic
Read my suspension article on the forth-coming issue of Fast Ford for an explanation as to why these are absolutely CRUCIAL to achieve a good handling Cosworth.
Regarding the beams, you pays ya money and ya makes ya choice.
The basic Zoo one starts at Ł550, you then add Ł150 for a strapped version, then Ł150 for the Motorsport spec rose joints. IMO I would definitely have these
Ahmed's fully adjustable beam with the Motorsport spec rose joints (the only type he is prepared to supply) is Ł1k + cost of painting.
I don't know how much Danny's are.
All this is plus fitting and setting up (which is the most crucial thing)
Did Someone Mention TUV
So would the basic zoo beam give a much noticeable improvement over a standard cossie beam? What benefits does the strapped version and motorspec rose joints give you?
Reason i ask is because if i bought the basic zoo beam then i could also get chassis bars and rear strut brace from danny b and a proper front brace from captain gaybird. Or would i be better off forgetting the chassis bars and strut braces and getting the all singing all dancing zoo beam
Caraholic
Originally Posted by pete mcrash
do u use like lasers n shit to set them properly.......or can quick fit do them..............???????
Caraholic
Reason i ask is because if i bought the basic zoo beam then i could also get chassis bars and rear strut brace from danny b and a proper front brace from captain gaybird. Or would i be better off forgetting the chassis bars and strut braces and getting the all singing all dancing zoo beam![Confused](https://passionford.com/forum/images/smilies/icon_confused.gif)
The strapping gives extra strength. If you are on a tight budget, I would go for the normal beam and spend the extra on the motorsport spec rose joints. Make sure you ask Brom for the extra long adjustment bolts, as his standard ones run out of thread when trying to achieve over 2 deg neg and 3mm toe-in
By the way, there is a strut brace sitting here with your name on it, you do spell it M A D C O C K S U C K E R don't you?
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
![007](https://passionford.com/forum/images/smilies/bond.gif)
What about the chassis bars and strut braces. Is it worth getting them as well or just spending my hard earned on a full spec beam?
Caraholic
Beam first, other stuff later. Unless Danny can do you a corking deal on all three
Autronics or handling, handling or Autronics. hmmmmmmmm
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
Happily retired
Rod
ps. I have a Zoo rear beam & Adrenaline chassis connectors, both rubbish no doubt according to you.
Adrenaline's rear beam price is on this thread i think -
http://www.adrenaline-race.com/forum...opic.php?t=500
