Oops, we've upset scoobynet........lol
Old 13-09-2004 | 04:42 PM
  #161
Ok saying ure supra is shit is a little harsh.
Old 13-09-2004 | 04:44 PM
  #162
Rich@rd's Avatar
Rich@rd
Like Mark from M.A.D. once says :
Scooby engine .. "The engine of glass"
Old 13-09-2004 | 04:48 PM
  #163
Anh's Avatar
Anh
Originally Posted by Phil
You really don't have the slightest clue about cossies do you
328 cc @ 3 bar injectors from a Cossie flows 328 cc per minute, the SAME as a 328 cc injector from another car! Cosworth engine isnt special, nor is it an exception to calculating BSFC.
You need ATLEAST 0.5 lbs of fuel per HP per hour.
328 cc x 4 = 1312 cc per minute
1312 / 1000 = 1.312 litres per minute
1.312 x 60 = 78.72 litres per hour
78.72 x 1.63 lbs = 128.3 lbs per hour
128.3 lbs x 2 = 256 HP
This is with the standard cosworth fuel pressure of 3 bar.
Old 13-09-2004 | 05:06 PM
  #164
Ratty's Avatar
Ratty
NMS Stage 1+ uses standard injectors and makes 295bhp/320lbf ft.
Even stage 1 makes 270bhp/270lbf ft
http://www.norrismotorsport.co.uk/index2.html
Old 13-09-2004 | 05:13 PM
  #165
Anh's Avatar
Anh
At what injector duty? Which fuel pump? Where is the dyno at proves how much RWHP it can make with standard injectors and pump? How do YOU know what parts they used?
Old 13-09-2004 | 05:15 PM
  #166
T38Mat's Avatar
T38Mat
My friend also has a supra and also seems to get his tuning information from Gran Tourismo LOL He bought his 4 years ago for 19k and now its worth 7-8 max.
Doh. Goes well for a standard car though.
Mat.
Old 13-09-2004 | 05:18 PM
  #167
bbigman2000's Avatar
bbigman2000
Anh
love your rims bro
Old 13-09-2004 | 05:25 PM
  #168
Eder22b's Avatar
Eder22b
Hello.
Old 13-09-2004 | 05:27 PM
  #169
saphycozzie-adz's Avatar
saphycozzie-adz
lmfao @ performance stats from gran tourismo!!!
must say i do prefer the supra that looks like the bat mobile and not that red one.
Old 13-09-2004 | 05:59 PM
  #170
RaVeR's Avatar
RaVeR
please
Old 13-09-2004 | 06:10 PM
  #171
Ratty's Avatar
Ratty
Originally Posted by www.norrismotorsport.co.uk
Stage 1
This conversion is a huge improvement over standard and involves the fitment of a new "chip" to the ECU and the fitment of a new wastegate actuator. I use a genuine Garret –31 item as these are superior in quality and operation to the usual alloy type. In addition I advise the fitment of a K&N type panel filter in the standard air box. The boost is then set to 16psi, the spark plugs either changed or gapped as appropriate and along with a general setup around 270bhp/270lbf ft can be expected.
Stage 1+
This is a recent development of my stage 1 conversion and takes the std engine to an even higher state of performance. This conversion however can only be performed on engines in excellent health or those which have undergone a complete rebuild. Likewise the turbo must be in excellent condition and preferably be fitted with a 360degree thrust bearing. Again a new "chip" is fitted to the ECU along with a Garret -31 actuator, and suitable plugs fitted and gapped if required. For 2wd cars I advise the fitment of a 4X4 Sapphire Intercooler. Coupled with a full setup this chip allows the car to run in excess of 22psi between 2500rpm and 5000rpm, then dropping to 17psi by 6000rpm and finally tailing to 14psi at the 7000rpm limiter. This setup normally results in around 295bhp/320lbf ft.
All here
http://www.norrismotorsport.co.uk/cosworthstages.html
Old 13-09-2004 | 06:13 PM
  #172
Stu @ M Developments's Avatar
PassionFords Creator
Kindly reconfigure your calculations to reflect the correct base fuel pressure of 3.5bar. And welcome to PassionFord.
  #173
Stavros's Avatar
Stavros
DEYTUKURJERBS
Karls stg1+ uses FAR more fuel pressure than standard you goon.
And i thought base pressure was far more than 3bar? And bearing in mind its a rising rate reg, your talking well over 4bar on full boost even if it IS 3bar.
And a std fuelpump for a sierra cossie is good for about 400bhp so thas not relavent...
Old 13-09-2004 | 06:16 PM
  #174
Beat ya
Id say prepare to be shot down in flames for that im afraid Steve (Depending on his knowledge, but he seems well informed)... im off home for tea, il log in to evaluate the carnage later
Old 13-09-2004 | 06:18 PM
  #175
GARETH T's Avatar
GARETH T
Old 13-09-2004 | 06:24 PM
  #176
Fastmaul's Avatar
Fastmaul
K155MYRS
Hi can't be arsed to read the whole post so I'll jump in from here.
I used to drive aSupra Turbo, and they have the WORST handling
I've ever felt! Sloppy like one of Steves leftover whores!
Oh Hi, and Welcome, when I get home from work, I might read it from the
begining.
  #177
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
i'm fed up of seeing all these bloody scooby's on the road! notice that they all have their bloody blue jackets and hat's... and dress the family up the same! takes the piss. plus they they think they own the road! i love seeing a 15 year old cossie eat em for breakfast
can't wait to get my escos on the road and show em' who's boss!
Old 13-09-2004 | 06:38 PM
  #178
TIFF's Avatar
TIFF
Chasing Radders
I used to have the NMS Stage 1 Gunship conversion and it was proven to be over 300bhp with a Standard fuel pump and Standard Yellow injectors
Oh, and i know what parts were used as i watched Karl fucking use them
Old 13-09-2004 | 06:52 PM
  #179
avengerpenguin's Avatar
avengerpenguin
Ive mentioned this before but just in case the Supra owner is reading I have owned both scooby and cosworth, both modified, first power run I had on the scooby was running 286bhp at the flywheel and 195 bhp at the wheels, and that is STI power, it was then modded to run more hp and I can say as an everyday quick car the cossie is better and faster. And to get any decent horsepower from a scooby you also need to change the intercooler and turbo unless you get one of the models that came standard with the TD05.
Old 13-09-2004 | 06:59 PM
  #180
EIL132's Avatar
EIL132
RR was incorrect. No way a Scoob with that flywheel figure would lose 91bhp through wheels. Would be more like 40
Old 13-09-2004 | 07:06 PM
  #181
EIL132's Avatar
EIL132
Maybe it runs an FSE valve
Old 13-09-2004 | 07:18 PM
  #182
avengerpenguin
I will dig out the dyno sheet and post it, this was done at Interpro Automotive and I have not heard of any stories about their RR being out, but maybe. The that I was trying to make was that I honestly believe that the cossie is a better car
Old 13-09-2004 | 07:43 PM
  #183
Sorry, i dont see the relevance there James
Old 13-09-2004 | 08:36 PM
  #184
Davescoob's Avatar
Davescoob
Hi.......
Scoobies are best, just admit it and you'll all be welcome on scoobynet. No hard feelings
Old 13-09-2004 | 08:39 PM
  #185
LOL... Welcome to the asylum Dave
Old 13-09-2004 | 08:41 PM
  #186
Davescoob's Avatar
Davescoob
  #187
Rich@rd's Avatar
Rich@rd
hmmm ... I think the termites have called each other to come and visit us...
Welcome Dave...
Old 13-09-2004 | 08:49 PM
  #188
McPikie's Avatar
McPikie
At what injector duty? Which fuel pump? Where is the dyno at proves how much RWHP it can make with standard injectors and pump? How do YOU know what parts they used?................ blah, blah, blah, blah
Thanks to 3i for the pic
Old 13-09-2004 | 08:54 PM
  #189
Davescoob's Avatar
Davescoob
Nah, It's gone quiet on the other side of the fence.
I just thought I'd stick in a post since there's a photo of my arse on this site...... (strange but true!)
What's funny is if you changed the words over ford/scoob you could swap these two threads over and no one would know the difference
Old 13-09-2004 | 08:55 PM
  #190
EIL132's Avatar
EIL132
Sorry, had a few beers and was thinking of Lambchop/Matt Bell thing. Sorry
Old 13-09-2004 | 08:58 PM
  #191
Davescoob's Avatar
Davescoob
On another note yellows are 440cc's which should be good for about 330bhp on a well sorted 4cyl, 2.0l engine @4ish bar fuel press.
Old 13-09-2004 | 09:02 PM
  #192
gurnE's Avatar
gurnE
440cc??
No, yellows are more like 280cc from memory
Dark greens are only 382cc
Old 13-09-2004 | 09:05 PM
  #193
Davescoob's Avatar
Davescoob
I thought the colours were universal, maybe not true. Yellows were standard on my car and rated at 440cc's @2.5 bar.
Old 13-09-2004 | 09:06 PM
  #194
Disabled Account's Avatar
Disabled Account
Dave, were talking BOSCH injector colour codes here........
Could you be thinking of a 440cc yellow injector from another manafacturer????
Old 13-09-2004 | 09:07 PM
  #195
gurnE's Avatar
gurnE
Standard cosworth yellows are webber injectors aren't they?
Old 13-09-2004 | 09:13 PM
  #196
Davescoob's Avatar
Davescoob
This could well be true. Like I said, I had assumed all manufacturers used a common colour coding.
It would make buying injectors a bit of a gamble though if you're going by colours I would have thought?
Unless of course you alway go to the same manufacturer......
Actually, my current one's are pink, 550cc's. What would that be in the ford world?
Old 13-09-2004 | 09:17 PM
  #197
craigp's Avatar
craigp
:gayflag:
Old 13-09-2004 | 09:20 PM
  #198
Rich@rd's Avatar
Rich@rd
PMSL @ pattozs
Old 13-09-2004 | 09:24 PM
  #199
Davescoob's Avatar
Davescoob
Old 13-09-2004 | 09:25 PM
  #200
EIL132's Avatar
EIL132
Why is it Subaru love pink?
Quick Reply: Oops, we've upset scoobynet........lol
