CVH Stud and nut kits
I know these are available, just wondered how they work.
Is it just a case of fitting them in place of the headbolts, or does the block have to be drilled and tapped for them?
#1 in Spelling Club
Originally Posted by Phil79
So, If I was to have the sump off, and looked down the headbolt holes, I could see out of the bottom?
They are a direct fit. Old ones out, new ones in, but you should thoroughly clean the threads out before fitting the new ones. Ideally run a tap down there.
I still don't understand
I thought, insted of just a headbolt, where you tighten it down just from the top, with a std and nut kit, you tightened it from top and bottom for better clamping force.
Diagrams to help a numpty anyone?
07-10-2015 12:56 PM
