cossie technical ?
Old Sep 12, 2004 | 02:55 PM
bbigman2000's Avatar
bbigman2000
Default cossie technical ?
guys
is it normal for the header tank on the cooling system to bubble once the motor is switched off, there is no pressure in the system atall, its as if its boiling but the water temp isnt that high.
is this normal ? is it because of the water cooling pipe for the turbo ?
Old Sep 12, 2004 | 03:00 PM
CosKev3's Avatar
CosKev3
My 4x4 saph used to do it too m8
Even after leaving for fans to kick in and out it would still bubble
Old Sep 12, 2004 | 03:02 PM
bbigman2000
thanks bud appreciated, yep, I think it must be the water in the turbo cooling pipe thats still boiling, just worried me for a sec thats all, so I went to see a rally guy here and he said thats normal but just wanted other thoughts, cheers
Old Sep 12, 2004 | 03:03 PM
Ima-Racing500's Avatar
Ima-Racing500
When you switch off,the water no longer circulates so the water around the turbo cooling system boils up due to the turbo heat!!!!Totally normal.
Old Sep 12, 2004 | 03:05 PM
bbigman2000
thanks very much bud, appreciate your reassurance, especially as Ive got a near new engine JUST fitted
Old Sep 12, 2004 | 08:37 PM
Stu @ M Developments's Avatar
PassionFords Creator
Ensure your running the correct 4x4 cooling system and not a lashed on 2wd system as that caused far too many problems.
Im refering to the route taken by the turbo water return to header tank.
Old Sep 12, 2004 | 08:42 PM
bbigman2000
ok thanks mate, its on my escort, ive got a sapphy 4x4 here though so il have a look and make a comparison cheers stu
Old Sep 12, 2004 | 09:13 PM
JimmyRS2005's Avatar
JimmyRS2005
The water does continue to circulate for some time after due to convection. Not at the same rate as when it's being pumped, but still..You can even hear it if you listen closely
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
