External Wastegates.
Originally Posted by Porkie
why compliate things ?
Sad....
Wot do you know?
Mr 'i pay for everything on my cars and never get my hands dirty!'
As rapidcossie says I have carried out the conversion to my ERST and have to say it was a lot of work. I did it because I have a couple of special turbos that had odd flanges and no internal wastegate.
To make fitting one worth while your turbo should have a small turbine housing meaning you have to by-pass a lot of exhaust gas, also you have to take into consideration how much boost you want? again that dictates how much gas you want to by-pass the turbine. Finally if you have a 1600 you probally wont produce enough gas to make it worth while?
However if you want a conversion doing let me know.
Simon.
Simon.
you dont just fit a external wastegate because you wanna bypass alot of air
its as simple as,,, if the turbo you want doesnt have an internal eastegate you need an external one
it will piss you off soon enough
im sure christain on here made a flange what bolted to the exhaust side of a t34 to seperate the wastegate bypass from the main exhaust
just finding my feet
he actually wants screamer pipe i recon,,,,, he prob also wants antilag
bet hes never done over 130 on the motorway either
think christian can supply a gay screamer conversion for ya mate,,, would be cheeper ( just) than buying a t34, THEN buying a external wastgate THEN manifold THEN what what ever else
what ever happened to people modding cars for more power , have we all turned into posers
Originally Posted by Billy_RST
Ok mate.
Its a T304 Turbo, .63 ex housing, standard manifold.
I was thinking of getting an adaptor flange, 38mm wastegate what do you think?
Ok mate.
Stuart, do you think 38mm wastegate is ok for mine?
http://www.synapseengineering.com/
Do a real nice ext. gate
Have to agree with the majority, the screamer will do you head in...in a very short time
Ive got a 35r but i'm gonna run the dump pipe back into the system just a little further down.
Sad....
Wot do you know?
Well I knew EXACTLY why you want an External wastegate didn't I...
I think it will be a trick little mod, somthing a bit different to everyone else.
Also the noise!
Also the noise!
pointless arguing anyway... because you won't do it
Sad....
Wot do you know?
Also the noise!
Also the noise!
Thats the WHOLE point of doing it... Yeah
Originally Posted by GARETH T
spend your money is strip clubs,, you'll have alot more fun
look for massage palours that are "open late",,,,,, MUCH better value for money,,,, they even have a cd player in there so you can choose YOU OWN music
trust me thats the type of screaming you wanna be hearing,,, that and 80p for a pill to make sure you get the hour you paied for
not that ive tried anything like that,,,, honest
