Do Dump valves give any .....
Old 09-03-2007, 07:47 AM
CraigJ
CraigJ's Avatar
Default Do Dump valves give any .....
performance gains or advantages when fitted to a turbo engine? or are they just annoying and not worth the bother?
Just interested.
Craig.
Old 09-03-2007, 07:50 AM
saffsta
saffsta's Avatar
Each to their own really they arent essential unless your running big bhp tbh
Old 09-03-2007, 08:02 AM
CraigJ
CraigJ's Avatar
i find it odd because its normally the small bhp cars that have them fitted and the high bhp 1 i've seen don't lol.
Old 09-03-2007, 08:05 AM
AndyBrew
AndyBrew's Avatar
fitted for the pssssssssstch thats why and if you like pssssssssstch then why not
Alps Pacino
Alps Pacino's Avatar
Topbombingkid
Its al down to what turbo your runing aparently the gt seies garretts need them, so i'm ging to have to use 1 which i'm not overly chuffed about.
On a erst though there wank and not needed as they d more harm than good imo
Old 09-03-2007, 08:08 AM
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
You wont see any performance gains by fitting a dump valve. In fact i found i lost throttle response when using an atmospheric dump valve. But seeing as i use a t34 i binned it
Old 09-03-2007, 08:12 AM
AndyBrew
AndyBrew's Avatar
I believe there are issues with the atmospheric dump valves causing idle problems and such like due to the ECU getting duff readings of some description, this was certainly the case on both my Scooby Doo and my Evo.
Personally I quite like "noises" zaust, dumping, chatter, gearbox whining etc. but then I don't drive my car everyday my escos currently has very little in the way of noise polution, it even has a standard airbox, time for some tweaks I think
Old 09-03-2007, 08:24 AM
Dicko&Vacant
Dicko&Vacant's Avatar
its better for your turbo if you use one though as iirc wastegate chatter is the air forcing back thru the turbo in the wrong direction..... sou nds good though
Sarah
Old 09-03-2007, 08:36 AM
Oranoco
Oranoco's Avatar
On a Cossie or RST? Is it buggery
Old 09-03-2007, 08:39 AM
SassyRS
Little Miss...
SassyRS's Avatar
I personally dont like them... but u can get recirc ones with no pttsshhhhhh
Old 09-03-2007, 08:46 AM
Miss Fiesta Turbo
Miss Fiesta Turbo's Avatar
I find that the car is slightly (not much but enough to be noticeable!) more responsive with the chatter... but i like my dump valve noise! so i change it over every few months!
SapphyMike
SapphyMike's Avatar
Dont they cause momentary turbo over speed when dumping, which is bad in itself?
Old 09-03-2007, 08:49 AM
Stavros
DEYTUKURJERBS
Stavros's Avatar
they on standard cars as a noise suppresion device and it will very very very slightly increase turbo life.
the "GT series needs one" thing is debatable, as i know of loads of people running GT series without them, maybe its just GT35+ that needs them as wheels are so big in comparison to the spindly lil centres.
Old 09-03-2007, 08:50 AM
Oranoco
Oranoco's Avatar
Was just about to say does Christian run without on his GT series turbo?
Old 09-03-2007, 08:55 AM
SapphyMike
SapphyMike's Avatar
We run one on a GT30 equipped cossie..
Old 09-03-2007, 08:59 AM
Stavros
DEYTUKURJERBS
Stavros's Avatar
Ive seen road legal competition/track cars running GT30 sized turbos (well, pushing 450-500 horse and 1.5bar+, so about that) running with no water cooling and no DV and no ill effects, so its a strange thing really.
Old 26-04-2007, 09:56 PM
Jimboxr4x4
Jimboxr4x4's Avatar
I heard that they are only needed with big turbos and that they actually sap power and response on a small turbo car.
I also heard that when the dump valve breaks they will allow excess boost and can knacker the turbo.
I've still got mine connected though.
Old 26-04-2007, 10:17 PM
Benni
Ban[B][/B]ned
Benni's Avatar
When I asked this on a different forum I visit when my brother owned a turbo car I was told chatter was bad. Basicly told the same thing Sarah was told.
Old 27-04-2007, 08:59 AM
The only way a dump valve of any sort can sap power is by being open in the dump position which you would hear.
The only way to lose power is by losing boost, a dump valve does not allow excess boost if it breaks and it is a diaphragm one it leaks and LOOSES boost, if it piston type it will cause or try to cause turbo stall, which of course is an extra strain on life of turbo.
I have all three, recirc, atmo and none(chatter)
Old 27-04-2007, 09:35 AM
Sticky.
Sticky.'s Avatar
Exactly what im doing
Old 27-04-2007, 11:44 AM
SafeChav
SafeChav's Avatar
Chatter is bad for a turbo in the long run, largely influenced by the size of the turbo though and how much boost is being run.
theres a VERY interesting thread in the technical essay archive on the subject, written by the man himself, Stu
Old 27-04-2007, 11:49 AM
Stavros
DEYTUKURJERBS
Stavros's Avatar
On most cars/engines your turbo/engine will fail for other reasons WAY before chatter fucks it.
Hence why most fuck it off.
Can give it all the theory people like, but enough people have tried to give results.
And you damn well CANT hear em when driving when they leaking slightly, which is common enough, from them slightly lifting from their seat at full boost etc etc.
And overspeeding a turbo like that will do will fuck a turbo a whole lot sooner.
Old 27-04-2007, 11:59 AM
RichardPON
RichardPON's Avatar
Would ALWAYS have some sort of valve, re-circ or otherwise on something like my MR2.
Shonky Jap ceramic turbos...
Old 27-04-2007, 12:26 PM
rs shawn
S1 Database Editor
rs shawn's Avatar
None of Martin's BTCC cars have D/V's neither. Remember ND last year with them whizzing around chattering their balls off.
Old 27-04-2007, 12:27 PM
S2martin
Ex Full Price gold member
S2martin's Avatar
But do you HAVE to Rich or is just you feel a bit safer with a valve?
Old 27-04-2007, 12:36 PM
dojj
Resident Wrestling Legend
dojj's Avatar
i had 2 on my twin turbo
made a great noise and there was no loss in performance either
i'm waiting for it to come back JUST so as i can hear the "PTSH!!!" again
Old 27-04-2007, 12:44 PM
SafeChav
SafeChav's Avatar
Originally Posted by Matt J
Can you adjust Re-circ valves so that it only does it at a preset boost level?
I know you can adjust dump valve springs to do the above, are re-circ's the same?
Dont forget dump valves operate off vacuum pressure not boost
Old 27-04-2007, 12:47 PM
RichardPON
RichardPON's Avatar
I don't think I could say for certain that you would HAVE to.
However, those turbos aren't known for their strength, but they never run huge boost either.
MR2 lot tend to think that 1.2 bar is massive boost!
Old 27-04-2007, 12:49 PM
AlexD
Post Miester !
AlexD's Avatar
I dont think there any performance gains..
I just run one to try and reduce the turbo wear, otherwise i would bin them
However School Girls love them
Old 27-04-2007, 12:58 PM
S2martin
S2martin's Avatar
What sort of power would you need with yours mate before the turbo becomes an issue reliability (spl) wise?
Is the MR2 not used for modding as much as the other Jap stuff?
(sorry have no idea always had Ford blinkers )
Old 27-04-2007, 01:28 PM
RichardPON
RichardPON's Avatar
Turbo is only really any good on mine for 1.1 bar tops, but it has an AFM setup, similar to a small turbo Esc Cos.
Later cars have more scope for tuning, and there are a couple of high 10 second cars in the UK.
Old 27-04-2007, 01:44 PM
Lou Lou.
Lou Lou.'s Avatar
I hope this is the case as i cant stand dump valves! my car chatters its ass of which sounds the bollox but im guessing its not that good for it?!
Old 27-04-2007, 01:52 PM
SafeChav
SafeChav's Avatar
As i say slightly further up the main influence on it is the actual size and amount of boost you run.
All the 200SX boys take the re-circs off and they seem to run forever and day chattering, they run a GT28 i believe
Old 27-04-2007, 02:33 PM
Lou Lou.
Lou Lou.'s Avatar
Well spec of my turbo is big turbo Escort Cossie front housing, T4 compressor wheel, roller bearing core and a small turbo Escort Cossie rear housing only running 23psi
Do you think this is ok without a dump valve??
Old 27-04-2007, 02:38 PM
Stu.H
Stu.H's Avatar
They LOVE the chatter more, especially as its SOOOO much louder as well
Old 27-04-2007, 02:49 PM
lead_foot
is awesome
lead_foot's Avatar
S13 are a T25
S14 are a T28 as standard.
I blocked off my re-circ last night on my S14, Happy times!!
Old 27-04-2007, 02:52 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
S13 are a T25
He means when they modify them. I think.
Old 27-04-2007, 02:58 PM
lead_foot
is awesome
lead_foot's Avatar
Ah right, Disco potato all the way
If I ever fix my misfire, i'll probably get a disco potato as my T28 is on the way out.
Quick Reply: Do Dump valves give any .....
