S1 front mounted intercooler question....
Couple of quick questions for those who've upgraded to a full front
mounted intercooler on their series 1.
What cooler are you using?
what fan do you use?
A mate is thinking of buying one for his mk3 project, and seein as you lot are a font
of usefull knowledge thought i'd see if anyone has any recommendations, or have good/bad experiences when using one!
CheeRS in advance.
CheeRS in advance.
i have a grs front mount with twin spal fans only problem i had at the start is that i had to cut a chunk of my caer away to fit it and it completely blocks the radiator so it was always running hot so i replaced the thermostat with an 85 degree one and it seems fine now and the act temps are well low
i had a grs with the fan that grs supply with it. had to chave about 3 mm out of the slam panel for the fan to go in properly, but never ever had any high temp problems on a standard cooling system.
only issue for me was that the top hose to the charge carrier needed to be about 3" longer than the one I already had.
Cheers for the replies folks....
DINGY
How's the double 2wd done?
Are the inlet and outlets on different ends?
Markb s1
Do you recommend the stuff you've got?
apart from the top hose issues!!
CheeRS again lads, most appreciated!
DINGY
Markb s1
pro alloy s2 intercooler with s2 boost hoses.
had to use a s2 rad but i already had one due to an s2 turbo.
work well for me,
had 2 smallish fans but had overheating issuses i wrote the car off before i had a chance to fix it.
work well for me,
vdun01
Ford Fiesta
05-10-2017 08:14 AM
