for ecu gurus....
any of the ecu L1,L6,L8 and P8 can run 8 Injectors with the correct boards.
cant see the problem in using it on a V8. Probably already been done.
The F40 runs 2 P8 ECU's
just though of an issue.
dont think the ECU is capable of anything more than firing 2 coils,
Im sure some of the tech ECU guys on here will be able to shed some light.
but i presume u will need a minimum of 4 coils to be fired?
Unless u can run 2 ECU's like the F40's
i would think away from the webber stuff,,, as of cause you would need the ecu's to get mapped,, and your not talking cheap money then!
once you buy 2 ecu's, a tidy custom loom for them both, remap them both,,,,,,dont bother
buy a aftermarket unit
i might have an f40 wiring diagram here if you wanna see it
this is merely educational at the moment by the way! the engines seem to run a single coil,but the dizzy cap would OBVIOUSLY have 8 leads to the plugs coming out.
go on gareth,put up the pic,baffle me!lol!
im just thinking out loud as the price of cossie ecus is rather...erm....cheap at the mo!
Originally Posted by RS2300 4x4
Gareth,yeah i thought as much,but thought i should ask first!
Mark
Why use a Cos Ecu?
Ford v8 Ecu are cheap and readilly available.
They run on eec 1V same as Cos?
There is a multimillion dollar industry in the states providing off the shelf chips to any spec far cheaper than the cost of mapping in the U.K
Almost every configuration of engine build has already been mapped.
If you need more power it's easier and cheaper to bolt on power, you don't have to go to the edge of reliability.
The V8 Ecu looks identical to the Cos and even uses the same 60 pin connector.
The standard Mustang Ecu will cope with 350bhp without any alteration.
Am I missing something, did you just want to make it hard and expensive work?
There are at least 2 add ons that allow you to modify the mapping at home.
no you didnt miss anything.ive been looking at currently carb fed motors and have seen l6s and l8s for a small amount of money and was merely wondering if it would work,and 350bhp isnt enough!
this was merely to ask a question out of curiosity.
just because an engine has 8 cylinders, doesn't mean it needs 8 injectors
There is only one company that I know of that can map the dual ECU set us as fitted to the F40 and that is MSD. There is probably more tuners out there.
Not worth it I'd have thought.
DixieTheKid
14-09-2015 09:04 PM
