escort cab problems.....please help
Old Feb 18, 2007 | 11:27 AM
rauri's Avatar
rauri
up in smoke........
Default escort cab problems.....please help
mate of mine got an h plate escort cab...1.6 cvh efi,problem is this....the power drops off after 4000 ish rpm and it just splutters.it does this in neutral and all gears while driving
anyone any ideas?
Old Feb 18, 2007 | 11:48 AM
rauri's Avatar
rauri
up in smoke........
so far he has changed- coil pack, plugs ,leads , ecu , edis , fuel regulator , fuel filter, inlet temp sensor , water temp sensor, tps , the water temp sensor made a bit off a difrence
im thinking maybe injectors?
Old Feb 18, 2007 | 01:06 PM
zippyobrien's Avatar
zippyobrien
sounds like the cams worn to excess, that or theres an air leak or fueling problem
take the injectors out on at a time and start the engine (it should turn over on three injectors, check to see you getting the same ish amount of fuel out of them, also try changing the fuel filter
benw456
Sep 16, 2015 05:27 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
rogerxr3i
Sep 13, 2015 06:56 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
