Been offered an R&D 6-speed dog-box
DANISH cosworth abuser
Any appinions?
Just been checked, looks like new, i know it works but what about strength aso aso
Originally Posted by GARETH T
350 lb/foot
Have talked to the guy in sweeden, and he has used this on an engine with 560hp and 630nm, no problems?
Former Sponsor
the build quality and strength on these boxes can vary wildly,some boxes seem bullet proof then the next one seems to break if you change gear more than twice with them,there are different versions and the parts are not all interchangeable plus the box was redesigned to a different spec,then there are direct top and overdrive.
also depending on year some boxes have a different pitch on the gears.
the layshaft can seize into the transfer caseing making removal almost impossible on the earlier boxes.ok when its not broken but a large problem if you need to rebuild it,
parts are in stock though and apart from there coustomer services needing some improvement they are not badly priced for spares,
as like any dogbox its there history/rebuild that counts,and make sure who ever has alledgedly rebuilt it knows what they are doing.quaife are also very hit and miss,they tend to select two gears at once and destroy them selves in the process.
if you can find a 4.4 rear diff and step off then the original sport box takes some beating.
ive just sold an r+d overdrive box for Ł2,000 with zero warrenty.
if you can afford it and are serious about using your car then get an FFD,
Am serius about the car, but havent got THAT much money for an ffd thou, even that i know it`s the best there is
Former Sponsor
mark is correct,long term it will cost much more and an FFD will only go up in value now,i think the list price at the time off ford was Ł37,000 plus vat.
plus an ffd gear cost the same as a quaife/r+d.
Former Sponsor
you can use what ever size diffs you want,
iam sure if you asked about you could find two 7 speed FFD with handbrake release for sale plus a 6 speed FFD with active centre diff for sale,try the rally car specialists.
Former Sponsor
thats just had a full rebuild.
all jokeing aside ive one 7 speed FFD that has just been rebuilt,i spent about 3k on it and its since done 70 miles,
ive another 7 speed FFD here that needs a dog ring for 2nd gear but iam going to get it fully overhauled as ive a pile of spares here for these,
plus ive the 6 speed FFD in my car ive just baught,got my eye on a world rally car so if i can do the deal this week then it will be for sale.
Originally Posted by marco polo
hi lads
good old dyno to make sure the boxes are ok
with a nice FFd on there
marco
marco
Hi Mark
yes mate handbrake release
working on a new design sequential box inline 4wd and 2wd box @ the moment
one of 4wd is being tested on a famous 4wd rallyX car and driver with 650 bhp
marco
Hi Tim
yes that one on there is a converted H pattern dog to sequential
we can do it to any h-pattern dog box even the Mt 57
we are going to build sequential striaght cut Mullit box in Mt 75 casing for you rally/track cars at resonable money
alot less than the FFD
there is a market for one
marco
marco
07-10-2015 12:56 PM
