people with carb knowledge
right,stavros is outside in the volvo 360 and it wont start,turns over ok,hes getting some spark,but unsure on fuelling. he has undone the fuel line to the carb and when turning over there is no fuel coming out,is this right?does it require vacuum etc from the carb to come out?or should the fuel pump be hoofing the fuel along the lines regardless?cheers
If he takes the fuel pipe off the carb and sucks really hard
, he should be able to suck some fuel through. This would mean the mechanical pump is goosed
, if no fuel comes through its either a blockage of ran out of fuel lol. Thats if it is a mechanical pump wich it should be. Could also try removing the fuel cap incase its a blocked breather
Bri.
Bri.
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
he's reading the haynes and apparently it says that insufficient fuel in float chamber can cause non starting,and he dont think theres any in it,but if theres none in there does that stop more coming in?ie does he have to put some in there himself?cheers again
DEYTUKURJERBS
mechanical pump must be bollocksed, its got plenty of fuel.
should always be fuel pumping through that pipe when cranking over, but its not.
scrapyard time, im not changing that shit, esp when i got a better (and injection) one coming.
BTW, this was all on my driveway trying to fix it, i wasnt stuck anywhere, jus didnt have internet access to ask.
DEYTUKURJERBS
Originally Posted by big_wig_074
do you reckon those fuses going all the time could have been summit to do with the pump?and we blew the bugger up?
Anyhow, i even mentioned it...
a mechanical pump is driven off something internally like that crank/camshaft depending on what engine it is, so has NO electrical input whatsoever. My old mk1 escort pump went, and i just fitted a Facet electrical one instead, and blanked the hole off.
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
rsguy
44
29-09-2015 03:29 PM
