MULLIT TRANSMISSION
#42
marco...what options would i have with 2wd?
prices for these too mate![Top](https://passionford.com/forum/images/smilies/smile011.gif)
i can do you a MT75 2wd Big Tooth striaght cut version no problem
or a full on 6 speed sequential rwd box
close ratio
6 speed & reverse in-line racing transmission box,
max :700Nm/500ftlbs engine torque,
sequential dog clutch gear selection,(6 dog)
dog selected reverse ,
aluminium alloy casing
weights about circa 38kg
internal oil pump,
semi dry sump with fully intergrated oil distribution system
rear drive concentric with crank
input drop gear ratio 1:1
1st ...........3:1
2nd...........2.13:1
3rd............1.59:1
4th............1.25:1
5th............1.12:1
6th............0.96:1
extras
mag alloy casing
loads of different ratios even closer or wider pick an chose ,
sequential handset with reverse actuation,
rotary potentiometer/electronic gear indicator
drop gear selection
only a cool 7.5k
marco
#44
2Evos & 1 Escort Van :-)
Originally Posted by JTECHSAFF
Big thanks to marco ,for sorting the box for my cossie ,truely an awsome bit of kit, fitted it today.
loving the noise aswell. people do seem to stare now
also ,big thanks to Si b and Doug stirling for helping me get the box up to be built
And again to si b for the offer of helping me to fit it today, i wont forget it mate.
even if i had beaten you to it
![](https://i58.photobucket.com/albums/g280/JTECHSAFF/mullitbox1.jpg)
anyone thinking of this conversion....do it
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
Even happier that you'd done all the hard work by the time I made my offer
Glad you're happy, enjoy the road testing and see you at the meet tomorrow
Si
#45
must have a carlo fandango rear diff then
euan
this what you will need eventually
![](https://img.photobucket.com/albums/0703/marcopolo/30012007059.jpg)
![](https://img.photobucket.com/albums/0703/marcopolo/30012007058.jpg)
![](https://img.photobucket.com/albums/0703/marcopolo/30012007057.jpg)
a brand new 9" with either Viscous Coupling or X-trac plated with any CWP of your choice
marco
#46
loud enough!
proper sounding box!
My car should be back and running by the end of the month - I'll do another batch of running in past your place again and you can see / hear it first hand
Just like last year then... will prob need directions again, your place is tricky to find!
Si
#47
euan
marco
Saying that I'm sure the diff you supplied me should be up to the job
I'm more interested in the sequential 4x4 box you've got in the making... you only have to shout if you want that one tested as well
Si
#48
Si
Hi Simon
the 4wd version of the full on 6 speed sequential rwd box
is being tested in a rally X car and by a famous Rally X driver
that will give it the ultimate test it will be expensive but not for what your getting if you know what i mean
trust me if i had another i would defo let you test it
marco
#49
just under 3k
but there lots of extras you can have on top
hi peeps
the extras with this box if needed
uprated 1st gear
uprated mainshaft
uprated center Viscous Coupling from 60Nm to 180Nm
uprated step off chain for when your using 3.9/4.1 rear diff ect still keep the 3.62 front diff
Big Tooth 5th gear with 0.76
marco
#56
Location: Salford I used to think I was indecisive, but now I'm not too sure.
£7500 for that sequential box is a bargain i think to be honest
Make your car a whole lot different especially againt the
RICE MOBILES.
RICE MOBILES.
#57
close ratio
internal oil pump,
1st ...........3:1
extras
mag alloy casing
drop gear selection
only a cool 7.5k
marco
JAP CRAP
32
03-03-2005 05:24 PM
Rich@rd
15
15-07-2004 09:26 PM
