Drilling hole in stainless steel exhaust?
Hi again was wondering if anyone new what sort of drill bit is required to well drill a hole in my s/s exhaust as no one around birmginham seems to be able to do it. I need to get this closed loop hooked up soon and start saving cash on petrol or just drive more Alex.
No-one around Birmingham huh???
I am sure there is a company beginning with a R based around there...
And if its too tough a job for Martin.... I am sure he has a pet Gibbon that has the skill to drill a fooking hole in an exhaust
Originally Posted by topaz
angle grinder
You should be ok with a normal HSS drill bit as long as you drill at a slowish speed and don't burn the tip out, if it squeels your going too fast lol
Bri.
Bri.
Hole drilling !
I kind of figured that a normal hss drill bit would work with a step bit after just wanted to check as exhausts arent cheap lol and i have nothing against the local companies ie. Mr Hadland! but i like doing the work myself well as long as its not another heater matrix
So yet again fellas thanks for the advice hole will be done tomorrow and boss welded in for closed loop too Alex.
Super Moderator
