General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
i think there are 96 teeth on the rings front and rear
as for the gaps, they are very close but without getting some measureing stuff out i wouldn't be able to tell you till at elast this evening
a few from the front and rear
as you can see the fronts are much deeper than the rears whic only go in for around 5mm as opposed to the fronts which go in about 25mm
as you can also see, the fronts have a tendancy to break when you try to remove them
