SiB's Engine RE Rebuild! PIX and UPDATE PAGE 2
As some of you know I broke my engine a couple of months ago
Well here's the pics of the affected part, it's been lightened and ventilated!
It's taken me 2 months or so to decide whether to go through all the hassle I had this time last year (some of you may remember my NURBURGRING countdown post last year!)
Well, seeing as the Ring is coming up again I've decided it's got to be done!!!!
So armed with my shopping list the RErebuild starts again
Oh, and this is going on to replace my weedy T38!!
What this space for updates!
Si
Si
BHP goal - anything over 450 would be adequate!! I've had a T3, T34.55, T34.63, a T38, so this seemed like a good plan.
Dave is correct - it's a T4. Old school, but who cares. GT30 plans are still on hold as realistically no time / money to do it before the Ring.
Big thanks to Escos Nige for the cracking deal, and to Doug Stirling for delivering it to me tonight
Also big thanks to my bro Sketch for stripping my engine earlier so I could get the photos and work out what to order.
My shopping list is as follows:
1 Cosworth 7.2:1 piston 4x4
Full set of piston rings
Big end bearings
Main bearings
Thrust bearings
4x4 Oil pump (High pressure one)
Cam belt
Cometic headgasket
Head bolts - large washer type
Valve stem seals
4wd bottom end gasket set
All Ł800 worth!
I've no idea what killed my car (apart from me!) but the injectors were tested and are 100% A OK. Big thanks to Phil (IMA / Boschman) for checking them
Si
Big end bearings
Main bearings
Thrust bearings
Cam belt
Cometic headgasket
Valve stem seals
All Ł800 worth!
Si
Originally Posted by smitsturbo
any pics of the car as im not good with names
& whats the bhp goal
This was the damage the little Deer did to my car at last Easter's Nurburgring trip.
This is a shot of the bore :
Got to get this bore linered - anyone know how much it costs to get this done? I've been quoted Ł130 - not sure if this is the right sorta money?
Good to hear that you are to ressurect the beasty Si!
Turbo looks very impressive!
I look forward to seeing her on the road prior to the nurburgring for a shake down.
JJ
JJ
Good to see I'm not the only one planning to run big power on a linered block.
3+4 have had liners fitted in mine and it will now be on a T38 so I can only pray it will hold together.
Why the change from the T38 ?
Good to see its all coming together for you now
Only need to line the damaged bore so as to keep it a standard bore to match the rest otherwise youd have to over boar the whole engine to the size needid to clean up the damaged one
ouch
edited as I now think its only 1 cylinder that was linered
stickyPaul wants your t38.
Matt said you had been busy buying stuff and on a serious note, want me to take some spare cams this year?
Good luck with it all mate...hope this trip goes better than last year mate.
youd have to over boar the :
Originally Posted by Chip-3Door
You are going for just a hone and new rings on the other bores I take it?
Fair play Sketch, im sure that will be fine given the very low number of miles its covered
It's done around 3000 or so since the last build I'd guess, maybe more, maybe less. Will try and dig some paperwork out that will confirm it.
Hoping a hone and new rings will work ok on the other 3.
Si
Originally Posted by Lou Lou.
You crazy man! good luck with the rebuild hopefully you will have better luck at the ring this year and hopefully i might get a spin in your car this time
If it makes it there, you're on the list for a ride round while it still works!!! So better jump in within the first lap or so....
Si
Originally Posted by Lambchop
so is a lined bore ok then?
i have a similar problem at the mo
Not sure if anyone else has any experience on the matter, but I hope to run somewhere around 450 bhp with it... could be an expensive experiment
As it happens, yeah!!! Not sure if you have room, but a spare motor would be cool... I'm bound to brake it again.
How soon do you want a T38 matey? I'm planning on selling it in the next couple of months .... basically going to see how I get on with the bufty tart T4, and if all is ok the T38 will be up for grabs after that.
Nowt wrong with it, I just always had 500bhp as a target with this engine, and the T4 came up at a fair price so I had to have it
With your help (and complete spares package) hopefully this year's Ring trip will be better than last time!
Si
