Cossie engine bay
#44
Yellow aint my thing BUT each to there own
BUT you shouldn't be teeing into your MAP sensor pipe or fuel pressure reg pipe they should be 1 pipe only so change that and give it its own feed from plenum.
#45
#46
I am a sheep and will be going with blue on the rush (but thats also blue).
Your engine bay actually looks quite clean but (apart from the bits mentioned above) I would be looking for some new strut tops, header tank and filler cap
#47
#48
#49
coswurv Dont worry about Dave
Looks good Very Bright Will have to shoot over soon bud
Ps did you see Jay has a -31 Ps Jay when you about next
#50
Brightens it up , but a few other bits tidied up and it will look good , bit at a time sometimes like that when you get new stuff and put it on with old it ends up with yo changing and cleanning everything , happening to me at the moment
#52
1 hole = MAP sensor
2 hole = Fuel reg
3 hole = dump valve
4 hole = Not sure how you got breather plumbing in but bottom one is normal connected to this but normally taken off with aftermarket breather which you have.So Is spare (Boost gauge maybe )so need need to drill and tap nothing
#55
not my thing but its your bay so do it as you please
i only ment to by some samcos for mine the next week it looked like this:
with a rs500 cooler aswell ,once you start to spend you dont stop
#57
Paul if you did the Header tank in the BLACK WINCKLE Paint and some other small bits it will BREAK up the in your face brightness
Are you about over the wkend if so pop over mine you have my mobile number so give us a txt or call you can have a look @ a couple of bits i have painted with the winkle paint
Here a washer bottle i did last night came out VERY WELL imho As the paint is only Ł3 odd its cheap and realy breaks it up and looks
#58
#59
#60
amen to that
#62
S1 Database Editor
Originally Posted by gingeRS
should have followed the sheep and stuck with red or blue.
Originally Posted by BigErn
Theres nothing wrong with a yellow engine bay bud, its different from the norm and looks good.
#63
#66
Originally Posted by fudgeass
heres the engine bay on my 3 door, although there is something missing and i just cant put my finger on it
Is it solid or met ? If its solid its dead similar to my Rush
#72
Its sometimes hard to keep cleaning stuff all the time , well it hought so , heres my old saff which was a nightmare under there to keep clean , and vowed if i ever got another cosworth i would be doing it slightly different so its lower maintanance
old saff
My current 3 door
now its just a wipe clean , and also looks ok , maybe not a striking as the bling one but still ok
old saff
My current 3 door
#73
dont think it looks to bad myself its a work in progress so sure bits and peices will be added over time but would defo relocate the amel valve,oh by the way if u aint got one yet dont bother with i collins actuator in a words they r pants!!to big go for a garrent one the only choice!!
#76
Re: Cossie engine bay
Just fitted my new samco's to it what do u think ?
Looks fucking awful
I answered your fucking question, you tatty clothed little gypo cunt!
honestly!
If you're going to post 'look at me, what do you think of my engine' posts.. at least make sure the pictures dont show some cheap pykey scumbag fucked old saph engine with dubious colour coded hoses and pykey bodge job repairs.
Now go and sniff your grandads piss soaked pants you thick , inbred uneducated cuntflap!
no kid gloves on there
#79
Looks fucking awful
honestly!
#80
the yellow is growing on me now i see it in your sig
or is it something else
realy tho if water or air can go through them i dont care what colour they are.each to their own
