Does Piston Slap eventually damage the engine
Old Jan 19, 2007 | 02:09 PM
davidnormanuk's Avatar
davidnormanuk
Default Does Piston Slap eventually damage the engine
Just thinking about the Sierra Cosworth 2wd with its piston slap. With the piston moving from side to side in the bore wouldn't this eventually wear the bores uneaven?
Dave
Old Jan 19, 2007 | 02:26 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
the bores and pistons are already worn uneven hence the slapping
it's an old slapper lol
Old Jan 19, 2007 | 02:41 PM
davidnormanuk
Did they not slap from from new then?
I was reading through the original owners manual and it mentions piston slap in there?
Old Jan 19, 2007 | 02:51 PM
Turbosystems
Super Moderator
the first generation engines did but they were made in 1985
Old Jan 19, 2007 | 02:58 PM
davidnormanuk
Hmmm. Thats interesting. I'll have to to see if there's any dates on the book then as mines a G reg.
Old Jan 19, 2007 | 03:00 PM
xr4x4rs's Avatar
xr4x4rs
you wil find that its just 2wd engines that have piston slap
wasnt until teh 4wd they got rid of it by changing the piston design for the small end
thats why people use 4wd pistons to stop it
Old Jan 19, 2007 | 03:04 PM
davidnormanuk
I was told that they offset the gudgen pin on the 4wd ones to stop the slap. Will any damage be done in the long term then? I assume people just live with it.
Old Jan 19, 2007 | 03:07 PM
xr4x4rs's Avatar
xr4x4rs
davidnormanuk
opps that what i meant gudgen pin
not small end as there the same in all cossie conrods been a long day sorry
well as ive seen 2wd engines with no rebuilds and over 100k i dont see the problem
but with it long term is hard to say
Old Jan 19, 2007 | 03:12 PM
davidnormanuk
Apparently the cars had an engine rebuild 15k ago and new oversized pistons were put in so should be good for a few miles then. I've known bikes last a long long time with piston slap with no problems so I'll see how it goes.
Old Jan 19, 2007 | 03:34 PM
Turbosystems
Super Moderator
2wd sapphires had offset gudgeons pin as did the rs500
it was the first generation engines only that didn't, however some of these engines were in the early sapphires
Old Jan 19, 2007 | 03:36 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Doesnt the piston slap just occur on cold startup? after a few mins, pistons heatup-expand and all is well?
Old Jan 19, 2007 | 04:55 PM
abdr500's Avatar
abdr500
no it wount damage the engine but the noise will get worse in time and then damage will happen
Old Jan 19, 2007 | 06:38 PM
xr2i-carl's Avatar
xr2i-carl
yeah its only very quickly from cold
Old Jan 19, 2007 | 06:45 PM
nellyscossy's Avatar
nellyscossy
the good ole piston slap......my saph does it for a couple of minutes from start up...my 3 door dosent do it at all...but thats had a rebuilt engine from a saph put in it in the past
Old Jan 19, 2007 | 07:25 PM
DENNIS's Avatar
DENNIS
piston slap is common on all 2WD cossies due to the center gudgeon pins.
most high performance pistons get it as the center pin is better for high revving engines..
no real damage will happen as it only lasts for a little while when cold...
some manufactures still use it, and the noise is classed as " acceptable "
some pistons expand over that of the " norm " so have larger bores and get slap from that .....
as long as it is piston slap due to this and nothing else its fine.....
Rstar_man
143
Jul 20, 2020 11:16 PM
KW-rscos
11
Aug 31, 2015 01:51 PM
Tim Wharton
Aug 30, 2015 05:46 PM
ekjim
Aug 17, 2015 08:57 PM
Roosie
Aug 13, 2015 07:40 PM
