Help needed identifying Thickwall front diff case, pics !
Old Jan 17, 2007 | 07:25 PM
Tony Ryan's Avatar
Tony Ryan
Default Help needed identifying Thickwall front diff case, pics !
A pal of mine has asked me if either of these are thickwall front diff cases , wonder if anyone can help identify them , theyre both stamped with Ford on the outside if that helps at all !
Thanks in advance
Old Jan 17, 2007 | 07:33 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
a photo of the side in the driveshaft area would help..
Old Jan 17, 2007 | 07:51 PM
Tony Ryan's Avatar
Tony Ryan
ah , sorry , thought i'd phot'od the bits that mattered , is there any distinguishing marks ?
Old Jan 17, 2007 | 08:02 PM
wes's Avatar
wes
Isn't it the size of the threads that hold the bottom plate on that give it away? M8's on std diff and M10's on the thickwall item.
Old Jan 17, 2007 | 08:03 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
i thought it was m6 on standard, m8 on thickwall?
Old Jan 17, 2007 | 08:07 PM
Disabled Account's Avatar
Disabled Account
EDITED as I am not sure
My Quaife thickwall diff with 8mm threaded holes:
Old Jan 17, 2007 | 08:11 PM
Tony Ryan's Avatar
Tony Ryan
Im afraid i cant answer those questions but i hoped that someone could ! Martin , hes actually a customer of yours , bought a gearkit and a modded 2wd Swan neck for an external wastegate .
Hes been turned over a few times and has recently bought one of these cases advertised as a thickwall but i cant tell him if it is or not ( 4wd isn't really my thing )
Ive done 200 miles today to try and help him , hope he hasn't been done again .
Old Jan 17, 2007 | 08:18 PM
Martin-Hadland
Looking at all the pictures you posted ... they all look like std parts. A side view is easy to i.d. I would take a picture of Dougs but he will never know that we fitted a std part and sold his thickwall!! If someone posts a pic of the side view I will indicate the area to check..
Doug.... Saturday.
Tony Ryan's Avatar
Tony Ryan
Doug , did you edit because your not sure yours is a thick wall case or because of the stud size thing ??You also say yours is a Quaife thickwall case , do Quaife make the cases or are they Ford items ??
Old Jan 17, 2007 | 08:20 PM
Martin-Hadland
Dougs diff casing IS a thickwall
Old Jan 17, 2007 | 08:23 PM
Tony Ryan's Avatar
Tony Ryan
if it looks like the one in the pic he posted then theyre the same as the Cases i posted on the top of the thread . Is it really only the side view that can be identified then , and again i ask , do Quaife make the cases or are they a ford item ? Do Ford also pick them for 909 purposes ??
Old Jan 17, 2007 | 08:24 PM
Disabled Account
Martin - Saturday
Tony, mine is deffo a thickwall case as supplied by Bernie, when you put it next to a standard case, it is easy to tell them apart (from the outside - even without the cover removed)....
I edited because I was misled by the pic of the 8mm bolts/studs......
I recall some rally peeps use a standard case and fit a strengthening plate + they drill/tap for the larger 8mm bolts (6 mm fitted to standard diffs).
Old Jan 17, 2007 | 08:26 PM
Martin-Hadland
Some thickwalls had 'ford' cast into the casing but were made by quaife.
Old Jan 17, 2007 | 08:27 PM
Tony Ryan's Avatar
Tony Ryan
Thanks Doug , maybe i need a pic of std case then to help identify these ones .
Old Jan 17, 2007 | 08:29 PM
Martin-Hadland
I will post some pics tomorrow if no side view is posted tonight..
Old Jan 17, 2007 | 08:34 PM
wes's Avatar
wes
sorry yes m6 std and M8 thickwall, I was told quaife made them for Ford motorsport, so if it has Ford stamped on it it "could" be a thickwall item.
Old Jan 17, 2007 | 08:42 PM
Tony Ryan's Avatar
Tony Ryan
Thanks Guys , would appreciate any further info on this .
Old Jan 17, 2007 | 10:07 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
Originally Posted by Doug Stirling
Martin - Saturday
Doug, need a lift? I have a plan forming
Old Jan 18, 2007 | 05:43 AM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
martin my diff is on the floor in your workshop,ford thick wall. unless you have sold it to doug lol
Old Jan 18, 2007 | 06:26 PM
Tony Ryan's Avatar
Tony Ryan
up .
Old Jan 18, 2007 | 06:34 PM
Disabled Account
Yes he has
It's now my spare diff......only Ł 20.00 & a packet of Hoola Hoops.............proper bargain!
Old Jan 18, 2007 | 07:30 PM
Martin-Hadland
take a look at the area with an arrow on the second picture, this an easy way to spot a thickwall. Also look at the area around the top mounting bolt on the right.
Old Jan 19, 2007 | 06:52 AM
Martin-Hadland
up for Mr Ryan
Old Jan 19, 2007 | 07:10 AM
Tony Ryan's Avatar
Tony Ryan
Many thanks Martin , i'll forward those pics to Mr.W and see if we can solve this .
Old Apr 25, 2007 | 11:01 AM
RWD_cossie_wil's Avatar
RWD_cossie_wil
up to get the pictures
track.focus'd
Aug 12, 2015 05:53 PM
col93saphcos
Aug 7, 2015 03:21 PM
xr4x4rs
Aug 6, 2015 09:03 PM
