T34 turbo which exhaust housing?
Hi fitting a new turbo with anti lag soon, what ehaust housing is best for accellaration(spel) a 63 or a 55?
thanks Dave.
thanks Dave.
Stu your getting to technical again
Basic spec, head ported with 26mm inlet port exhaust standard as are the valves.
BD14 inlet cam standard exhaust
7/5/1 compression ratio
and about 30 to 34 peak boost presure
I want fast accelaration really over top end speed.
Dave.
Dave.
Assuming you're definately using a T34 then surely you'd be better with the 0.63 housing if you're using ALS ?
I would have thought the larger exhaust housing would have enabled the engine to run more efficiently and with the ALS you won't be bothered about the slight reduction in lag that you'd gain using the 0.55 housing ?
Just my 2p worth.
Just my 2p worth.
Originally Posted by Turbo lag
good point EDD would the 55 restrict the gas flow at high boost( 34 ) then?
Dave.
Dave.
i have a 55 on a basic low comp stage 3 runnig 20 psi and am very pleased with the results as doesnt seem to run out of puff at all. pulls so much harder than stage1 but really feel it above 110-120 where it flies round to over 155.
im not an expert but just my opinon.....
Yes i still have my 55.
But as i didnt spot your going for anti lag i presume a .63 would be better for top end power as the anti lag will do it lower down whilst your waiting for it to spool up.
Matt Baxter
16-09-2015 08:30 PM
rsstav
Ford Focus RS Parts for Sale.
20-08-2015 07:45 AM
