drill size for thread tap?
Old Dec 23, 2006 | 03:09 PM
banhambuilt's Avatar
banhambuilt
Default drill size for thread tap?
i have a few 8mm threads to tap on the rs200 chassis,i have the taps but am unsure what drill size to use.
is there a drill/tap size guide out there?,i have googled but kept coming up with bath taps
cheers
dave
Old Dec 23, 2006 | 03:16 PM
S3an's Avatar
S3an
drill size is 6.75mm
Old Dec 23, 2006 | 03:18 PM
banhambuilt
thanks,dave
Old Dec 23, 2006 | 03:21 PM
focusv8's Avatar
focusv8
For next time:
http://www.wisetool.com/manufacturing/drill.htm
Old Dec 23, 2006 | 03:22 PM
St3V3_C's Avatar
St3V3_C
I usually use 7.2mm
You want the hole to be big enough that the tap then goes in easy, but not so big that there is no thread left. It will vary on the type and thickness of the material.
Drill a smaller hole and try the tap - if it's too hard, go for a bigger hole
Old Dec 23, 2006 | 03:25 PM
S3an's Avatar
S3an
Originally Posted by banhambuilt
thanks,dave
no problem Rodney
Old Dec 23, 2006 | 03:26 PM
banhambuilt
Originally Posted by focusv8
cheers
has all the sizes i need now
dave
Old Dec 23, 2006 | 09:23 PM
wirralphil's Avatar
wirralphil
K5SSY it's actually 6.8mm for a 8mm thread
Old Dec 23, 2006 | 09:24 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
If you're ever REALLY unsure - just go 1mm under the size of the M
That's not a particularly professional thing to do - just gets you out of a tight spot
Old Dec 23, 2006 | 09:30 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
always works though!
Old Dec 23, 2006 | 09:32 PM
Big Will_'s Avatar
Big Will_
Yup
Old Dec 23, 2006 | 09:38 PM
wirralphil's Avatar
wirralphil
This will help you for future referance
METRIC COARSE SIZES
TAP DRILL
SIZE SIZE
1mm x .25 .75mm
1.1 x .25 .85
1.2 x .25 .95
1.4 x .3 1.1
1.6 x .35 1.25
1.7 x .35 1.3
1.8 x .35 1.45
2 x .4 1.6
2.2 x .45 1.75
2.5 x .45 2.05
3 x .5 2.5
3.5 x .6 2.9
4 x .7 3.3
4.5 x .75 3.7
5 x .8 4.2
6 x 1 5
7 x 1 6
8 x 1.25 6.8
9 x 1.25 7.8
10 x 1.5 8.5
11 x 1.5 9.5
12 x 1.75 10.2
14 x 2 12
16 x 2 14
18 x 2.5 15.5
20 x 2.5 17.5
22 x 2.5 19.5
24 x 3 21
27 x 3 24
30 x 3.5 26.5
33 x 3.5 29.5
36 x 4 32
39 x 4 35
METRIC FINE SIZES
TAP DRILL
SIZE SIZE
4 mm x .35 3.6mm
4 x .5 3.5
5 x .5 4.5
6 x .5 5.5
6 x .75 5.25
7 x .75 6.25
8 x .5 7
8 x .75 7.25
8 x 1 7
9 x 1 8
10 x .75 9.25
10 x 1 9
10 x 1.25 8.8
11 x 1 10
12 x .75 11.25
12 x 1 11
12 x 1.5 10.5
14 x 1 13
14 x 1.25 12.8
14 x 1.5 12.5
16 x 1 15
16 x 1.5 14.5
18 x 1 17
18 x 2 16
20 x 1 19
20 x 1.5 18.5
20 x 2 18
22 x 1 21
22 x 1.5 20.5
22 x 2 20
24 x 1.5 22.5
24 x 2 22
26 x 1.5 24.5
27 x 1.5 25.5
27 x 2 25
28 x 1.5 26.5
30 x 1.5 28.5
30 x 2 28
33 x 2 31
36 x 3 33
39 x 3 36
need anymore?
Old Dec 23, 2006 | 09:54 PM
crash_ash's Avatar
crash_ash
tried this when i was trying to drill a hole for M1 x 0.25 tap, can't get the tap into the hole tho!
easy way to remember, if your tap says M12 x 1.75 for example subtract the 1.75 from the 12 to give the tap drill size, in this case it'd be 10.2mm
Old Dec 23, 2006 | 10:09 PM
wirralphil's Avatar
wirralphil
Old Dec 23, 2006 | 10:12 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
depends on the pitch of the thread, but for metric its usually the pitch minus the diameter
so for a 8mm dia with 1.25mm pitch, a 6.75mm drill will be fine
but you can oly get prolly a 6.7 or 6.8 - either will be fine tho
Old Dec 24, 2006 | 09:06 AM
GARETH T's Avatar
GARETH T
buy one of those, and stick it in your garage toolbox
http://cgi.ebay.co.uk/BRAND-NEW-PREC...QQcmdZViewItem
Old Dec 24, 2006 | 09:11 AM
PatrickSwe's Avatar
PatrickSwe
Correct!
ps,
Working as cnc operator in sweden, drills a lot of holes and thread´s them
ds.
Old Dec 24, 2006 | 09:21 AM
st3v3's Avatar
st3v3
Correct!
ps,
ds.
Not always true for Imperial pitches though
Old Dec 24, 2006 | 09:26 AM
philram's Avatar
philram
Mulechild
you'll never need anything else, i've used mine every day for over 16yrs. the first thing i ever bought as an apprentice.. £5 now... blimey i got mine from whsmiths for 95p
Old Dec 24, 2006 | 09:31 AM
S3an's Avatar
S3an
think you will find it wasnt, seen as though he didnt say what pitch it is i was correct as stated in later posts on this thread.
Old Dec 24, 2006 | 09:46 AM
st3v3's Avatar
st3v3
sigh...you take the addendum and dedendum of the thread and adding them up thus giving the thread depth or .86603xp to give the fundimental triangle minus the basic crest radius,minus the basic root radius.
Take 60% of this depthx2 then take this figure away from the tap diameter, that should be about right for the hole size to be drilled.
Old Dec 24, 2006 | 09:56 AM
GARETH T's Avatar
GARETH T
Correct!
ps,
ds.
but normally we dont say the pitch of the imperial threads we say the teeth per inch, and of cause to work out thread depth from TPI you need the thread angle as well! i know you know this and thats why you said it though
Old Dec 24, 2006 | 10:20 AM
st3v3's Avatar
st3v3
Correct!
ps,
ds.
Old Dec 24, 2006 | 10:21 AM
st3v3's Avatar
st3v3
oops double post lol
Old Dec 24, 2006 | 11:34 AM
crash_ash's Avatar
crash_ash
i'll take your zeus book and raise you the "mechanical yearbook 1969" think it was 11d if i remember correctly
Old Dec 24, 2006 | 11:40 AM
st3v3's Avatar
st3v3
Ill raise you to "mechanical year book 1930 something "
which i have in my locker at work
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
yatta
May 21, 2016 10:31 PM
pabloXR
Sep 21, 2015 12:42 PM
alexbarnes95
11
Sep 15, 2015 10:26 AM
