3 Lambda sensors failed
Old Dec 22, 2006 | 06:37 PM
trevCOSS's Avatar
trevCOSS
Default 3 Lambda sensors failed
Over the past 4 months I have had 3 lambda sensors fail, Im running closed loop on my 4x4 saff, stage 3. Does anyone have any idea what could be causing the failures? Also what does the managment do under closed loop conditions if the lambda is not returning the correct signals?
Old Dec 22, 2006 | 07:15 PM
xr4x4rs's Avatar
xr4x4rs
im sure if a lamda sensor fails it runs rich
are they genuine lamdas or aftermarket?
if aftermaket could be the heat destroying them
Old Dec 22, 2006 | 07:55 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
bit weird that.... im sure if the lambda fails it would revert back to the standard map...on stu's chip would still be about 0.90% c.o at idle
ive got a spare genuine lambda if you want to try it mate....?
Old Dec 23, 2006 | 08:45 AM
Wardy257's Avatar
Wardy257
The most likely cause is becuase you are running rich all the time. O2 sensor do not like it, their job is to stop it happening. However, if the mapping is too far out the O2 sensor can not do it's job properly.
Old Dec 23, 2006 | 09:24 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
If the sensor is left switched on when the engine is off it will burn out. Worth checking to make sure it switches off...
Old Dec 23, 2006 | 10:35 AM
trevCOSS's Avatar
trevCOSS
Originally Posted by JTECHSAFF
bit weird that.... im sure if the lambda fails it would revert back to the standard map...on Stu's chip would still be about 0.90% c.o at idle
Mine isnt in the exhaust housing its a full sizeone
Old Dec 23, 2006 | 10:37 AM
trevCOSS's Avatar
trevCOSS
It runs closed loop witrh CO of 0.7% at idle when the sensor is working so its not running rich
Old Dec 23, 2006 | 10:50 AM
Wardy257's Avatar
Wardy257
That is at idle, how long per journey to you stay at idle?
Old Dec 23, 2006 | 10:59 AM
trevCOSS's Avatar
trevCOSS
Aftermarket which could be my problem, what is the reccomended sensor?
Old Dec 23, 2006 | 11:01 AM
trevCOSS's Avatar
trevCOSS
not very long, the last sensor lasted less than 100miles!
Old Dec 23, 2006 | 11:04 AM
Wardy257's Avatar
Wardy257
I would get on a rolling road and check you fueling throughout the rev/load range. 3 O2 sensors in a row, that quicky, is more than bad luck.
Old Dec 23, 2006 | 06:13 PM
trevCOSS's Avatar
trevCOSS
I have just ordered a new bosch LS02 sensor, hopefully this will allow me to finally have a sensor that lasts more than a few miles
Old Dec 23, 2006 | 08:18 PM
Stu @ M Developments's Avatar
PassionFords Creator
Ive used the LS02 sucessfully on cars that have now covered over 30000 mile without incident, many of them are members of PF too, so you should be fine with that one.
When we made this system we tried lots of cheapo brand sensors and all had teh same problem, early failure.
Old Dec 23, 2006 | 08:21 PM
trevCOSS's Avatar
trevCOSS
I got the part number from B9KOS sensor which came from you origionally I think stu so I knew it would be a good bet to get one of them, on a side note my wasted spark coil pack driver arrived today (i won it on ebay) so i have something to do on christmas day! solder it into my ecu
Old Dec 23, 2006 | 08:22 PM
I got the part number from B9KOS sensor which came from you origionally I think Stu so I knew it would be a good bet to get one of them, on a side note my wasted spark coil pack driver arrived today (i won it on ebay) so i have something to do on christmas day! solder it into my ecu
Excellent.
If you have any problem at all, let me know, happy to help you mate.
Old Dec 23, 2006 | 08:26 PM
trevCOSS's Avatar
trevCOSS
thanks Im sure it will be ok, the instructions are fine and im ok with this sort of thing.
Old Dec 23, 2006 | 08:27 PM
Cool, you will love it, totally different engine once converted to wasted spark.
Old Dec 30, 2006 | 03:46 PM
trevCOSS's Avatar
trevCOSS
Hi Stu
All fitted, bit of a rev counter problem and also I have sent you a PM about the instructions, other than that excellent, also have fitted my bosch LS02 and so far so good.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
SMILER258
Sep 28, 2015 09:04 AM
