Goddamshittin washer jets!!!!
Right ive got a problem with my washer jets on the Saff, they wont bloody work
i changed the motor a few months back, which still didnt help, ive got new jets which i know work cos took em off a mates car, if you remove the jet the water will come out of the hose quite easily, but as soon as you put the jets back on it just bubbles up and nothing comes out,
its getting pretty annoying as cant see a fooking thing when roads are wet, and usually have to tailgate a wagon to get a free screen clean
sounds like the jets are blocked
i had this on mine just took em off and put a needle down them and rinsed under the tap
put them back on and they have been fine once they are adjusted again
your bottle coul have bits of crap in it so the pump is pumping the shit uto the jets
might have to get a new bottle or take it off
pete- we drove from metro centre on sunday with a squirty bottle, its like pissing in the wind.... dont work
Is there a leak in the tubing? When you have no jets on - the ater takes the easiest route ie out the end of the tube, but with the jets on that end is restricted more and the water may be leaking out somewhere else.
Resident Wrestling Legend
sounds like blocked jets to be honest
even if they were working when you removed them, the fact that there might be crap in the pipes will just block them up again
remove the jets, poke them with a needle while in a bit of hot soapy water, give them a proper rince out and refit them, making sure that you plug them onto the hose to check if they are working before you properly refit them
i just get a needle.. shove it up both parts where the water goes in and comes out and attempt to remove all the crap and blow them out with an airline..
works most times
works most times
Not being cheeky, but hes alreadt said its NOT the jets -
ive just said that theyre new jets taken off a car which they worked in
It has the somewhere else in the water lines if the pump is working correctly.
it turned out to be blocked jets even though the jets weer fine off another car, found out that the bottle had bits of crap in it so the pipes were blocked
so had to give the bottle a clean aswell
could also have a slight kink in the pipe when you fite the jets aswell
Also make sure you have the connection to the pumps the correct way round or im sure one does the wipers on the head lights and if there the wrong way round you may be skooshing the light instead of the window
Re: Goddamshittin washer jets!!!!
just tried the washer jets back on the car they came off without even cleaning them and they worked so just to clarify to all the people who say jets are blocked lol they are NOT
so could it be either dodgy hose or weak pump?
Originally Posted by NUTTIN RILLA
You tried what i said mate?
cheers
155lee
06-09-2016 11:10 AM
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
155lee
24-10-2015 11:11 AM
DavidK
27-09-2015 02:55 PM
