Coolant hose question
Hi guys sorry for posting this in general chat but i need a quick answer please.
Just trying to replace the radiator, but all the large black coolant hoses are being a bitch to get off. Are they put on using heat? Should I get a heat gun? Or just pull really hard? I dont want to break anything and need to put them back on the new rad.
Thanks in advance
Thanks in advance
Testing the future
best way is to carefully insert a medium size flat blade screwdriver between the pipe and the fitting and gently ease it around the circumference to break the bond
Testing the future
xxx did it work? are they off, and how did you do it?
or did you do this and skin your knuckles?
Originally Posted by lukeytheduke
or just wiggle, push and pull as hard as you can in a rotating motion
