Sponsored by:
Sponsored by:
Well Done Simpson Race Exhausts
Old 16-12-2006, 07:21 PM
  #41
GARETH T
GARETH T's Avatar
thats not a bad proce for alot of skilled work
Old 16-12-2006, 07:23 PM
  #42
Fiecos Dan
Fiecos Dan's Avatar
Not bad.
i bet materials was nearly half that, and then 2 - 3 days labour.
Old 16-12-2006, 07:26 PM
  #43
Eagle
Super Moderator
Eagle's Avatar
looks good dave
Old 16-12-2006, 09:02 PM
  #45
mattb@corsasport
mattb@corsasport's Avatar
I had a full system made by matt and his guys last year for my lil old corsa, top quality stuff, was well impressed, and a year later it looks as though its just been put on.
I am intending to go there also when i get my 3 door
Old 16-12-2006, 09:07 PM
  #46
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
looks good but do something with the turbo oil feed!!!!
Old 16-12-2006, 09:29 PM
  #47
Fiecos Dan
Fiecos Dan's Avatar
i noticed that too,
why have you retained the 4wd set up?
Old 16-12-2006, 09:54 PM
  #48
Franco
Franco's Avatar
Why whats wrong with it?
Old 16-12-2006, 09:59 PM
  #49
Martin-Hadland
other than the fact that the pipe is getting all the heat that the turbo can throw at it... i can't see a problem..
Old 16-12-2006, 10:03 PM
  #50
Franco
Franco's Avatar
Paul R tried fitting a 2wd set up on his new engine, but couldnt clear the oil filter arm wih the block connector(if that makes sense!!).
Fouled it big time!
Old 16-12-2006, 10:05 PM
  #51
Martin-Hadland
Fouled it big time!
he did not try hard enough... i have done lots of these!
Old 16-12-2006, 10:11 PM
  #53
Martin-Hadland
Originally Posted by MAD YUM
This was a just for when we dynoed it...
This will get changed
cool... i did not expect less
Old 16-12-2006, 10:20 PM
  #54
Franco
Franco's Avatar
Fouled it big time!
Care to share via PM so i can bribe him!
Oh Look what i've done Paul!
PS Dave exhaust looks spot on!
Old 16-12-2006, 10:28 PM
  #55
Kelv
Almost there!
Kelv's Avatar
Looking good Dave.
not long now then
Franco, its easy mate, i had the 2wd setup on mine aswell!
Old 17-12-2006, 01:19 AM
  #56
Fiecos Dan
Fiecos Dan's Avatar
the 2wd set up is a better and direct flow, with cooler and cleaner oil.
Fouled it big time!
i never had a issue, putting my 4wd engine to 2wd oil feed, and i retained dash oil pressure light switch and got my Racetech oil pressure gauge take off there too.
Old 17-12-2006, 07:21 PM
  #58
radiant red
radiant red's Avatar
Default Re: Well Done Simpson Race Exhausts
Just like to thank Matt for a great job on Yum
http://www.simpsonraceexhausts.com/
Not Long Now
quality looking piece of work
but would the turbo oil filter be better placed not over the glowing turbo???
Old 18-12-2006, 10:38 AM
  #60
jbrayley
jbrayley's Avatar
Hi Dave, so what does she sound like? I want to hear some sound clips With regards to traction control with the SM4 does mark think its a good idea? I remember talking to him a while ago about it and he wasnt that keen on using it?
Old 18-12-2006, 10:57 AM
  #61
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Fouled it big time!
1 x Threaded in one end - v piece standard on 2 wd and Escort Cosworth for having oil pressure switch and oil pressure sender out of block - Ł15 + delivery.
1 x Threaded in both ends - is standard on 2wd Cosworth (no longer available from Ford) to have oil feed pipe to turbo and oil pressure sender on inlet side of block close to dipstick - Ł15 + delivery.
Old 18-12-2006, 12:08 PM
  #62
Franco
Franco's Avatar
Blatent plug!
Ps i'll use my own!
Old 18-12-2006, 12:09 PM
  #63
Mike Rainbird
Caraholic
Of course - never miss an opportunity .
Old 18-12-2006, 01:22 PM
  #65
Mike Rainbird
Caraholic
http://www.randbmotorsport.co.uk/sho...?ProductID=187
Old 18-12-2006, 03:30 PM
  #66
Rippers
Monte Geek
Rippers's Avatar
The reason I couldn't get the 2wd oil feed to fit was because I didn't have the adapter between the feed and the oil feed adapter as pointed out in this pic:-
I asked a few places and no one helped me out and impatience made me just fit the 4x4 one.
If someone is kind enough to find or sell me said adapter then I'd fit it esp seeing as I need to fit a new oil pressure sender anyway
Old 18-12-2006, 04:18 PM
  #67
Franco
Franco's Avatar
Does that mean you lose the oil pressure switch on the dash though Paul
Old 18-12-2006, 04:21 PM
  #68
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
Does it matter if you dont have the dash light as if it comes one whilst driving it is already to late. Better to keep an eye on a gauage really
Old 18-12-2006, 04:24 PM
  #69
Rippers
Monte Geek
Rippers's Avatar
No mate has the oil pressure adapter has two out puts and there is just a bung in the lower side
Old 18-12-2006, 04:28 PM
  #70
Rippers
Monte Geek
Rippers's Avatar
Us Esc Cos owners have a oil pressure gauge as standard
Old 18-12-2006, 04:29 PM
  #71
Franco
Franco's Avatar
Ahh thats the difference then as mines removed & had the defi pressure switch fitted at the bottom. Looks to me like you'd just fit the 2wd adaptor to the 4wd version
CossieRich
Shoot me if i'm talking crap but does the ECU not monitor Oil pressure?
But i'm sure the annoying light on the dash is only a lightbulb pull away!
Old 18-12-2006, 04:31 PM
  #72
PinkRinse
PinkRinse's Avatar
Brilliant stuff!!
I was really impressed with them when I went there to ask about the system on my car. They said it would take a week (due to be picked up the day I went to FITP this year) and she was done 3-4 days! I LOVE my exhaust and can't praise Simpson highly enough. People have commented time & time again about the quality of their work and thoughtful little touches like pins to stop the exhaust mounts coming off the hangers (which has happened to one or two of our members). I cant even remember how I found them but I'm glad I did!
Old 18-12-2006, 04:34 PM
  #73
Rippers
Monte Geek
Rippers's Avatar
Its the 2wd adapter that fouls the remote Oil Modine arm mate
Old 18-12-2006, 04:44 PM
  #74
Mike Rainbird
Caraholic
Paul,
Are you BLIND ?
There is one designed for 4x4s in the picture I posted .
Old 18-12-2006, 04:49 PM
  #75
Franco
Franco's Avatar
Thats not the prob though Mike!
Old 18-12-2006, 05:42 PM
  #76
Rippers
Monte Geek
Rippers's Avatar
Mike the ones in your pics are just standard ford copies..
The 2wd adapter won't fit with the 4x4 oil mondine arm
The 4x4 one needs a male to male adapter to fit the 2wd oil feed which I don't have/couldn't get
Now if your not blind please LOOK at the pic I posted there is a big RED arrow pointing to the part I need
Old 18-12-2006, 08:26 PM
  #77
foreigneRS
Testing the future
foreigneRS's Avatar
you're talking crap
that's a top job they've done there dave, you must be well happy with that
Old 18-12-2006, 08:29 PM
  #78
CossieRich
CossieRich's Avatar
Franco,
i wont shoot you. You are just mis-informed
Old 18-12-2006, 09:33 PM
  #79
Franco
Franco's Avatar
So my collins monitor wont read the oil pressure via the ECU then?
Old 18-12-2006, 09:38 PM
  #80
Damo V
Damo V's Avatar
No needs a seperate sender..
Quick Reply: Well Done Simpson Race Exhausts
